08-16-2003 05:08 AM - edited 03-02-2019 09:38 AM
I m getting this statistics from my 7206 in which we hv enabled CEF.whts the meaning of this statistics ??
CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 1798888 109955 176 69005 0 0
CEF Drop Statistics
RP 796152 1947 0 3155 0 0
Regds
prem
Solved! Go to Solution.
08-17-2003 03:34 AM
Nope, there's no way to clear those counters that I've ever been able to find.... I just went searching around through the code, and although the data structures appear to be in place to be able to clear them, I don't see where you'd be able totype anything on the command line and actually be able to clear them.
Russ.W
08-16-2003 07:58 AM
Or, if you happen to have access to the networkers presentations from a couple of years back, the ios troubleshooting session slides have some information on these, as well. I think we might have covered them, somewhat, in Advanced IP Network Design.
Russ.W
08-17-2003 01:10 AM
Hi russel
thks for the link..is ther any way to clear the stats ??or shuld i go for a reload ??
regds
prem
08-17-2003 03:34 AM
Russ.W
08-17-2003 07:27 PM
thks russel
regds
