01-30-2003 11:32 PM - edited 03-02-2019 04:42 AM
I'm mot sure if CEF is working att all.
We are running ios Version 12.0(4a)WX5(11) on the MSM.
CEF is enabled:
spt-3-4-ro#sh ip cef summary
IP CEF with switching (Table Version 19976)
628 routes, 0 reresolve, 0 unresolved (0 old, 0 new)
628 leaves, 99 nodes, 177132 bytes, 19981 inserts, 19353 invalidations
0 load sharing elements, 0 bytes, 0 references
2 CEF resets, 0 revisions of existing leaves
refcounts: 26756 leaf, 25600 node
Adjacency Table has 464 adjacencies
But show interfaces stat does not show anything in the route cache counters, everything is only in the procesor counter. According the documentation for CEF "Execute the show interface stats command and confirm incrementing hits for route cache inbound.
Note: The route cache counter includes both fast-switched and CEF-switched packets."
spt-3-4-ro#sh interfaces stat
GigabitEthernet0/0/0
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 870007615 62530716 1078052832 4127026129
Route cache 0 0 0 0
Total 870007615 62530716 1078052832 4127026129
GigabitEthernet1/0/0
Processor 1570042983 915192551 1748381344 767615756
Route cache 0 0 0 0
Total 1570064318 925970840 1748404255 774233914
Controller0
Processor 3815857776 857507335 1161121678 1409906790
Route cache 0 0 0 0
Total 3815857776 857507335 1161121678 1409906790
GigabitEthernet3/0/0
Processor 1260446871 986365264 714095684 2168919142
Route cache 0 0 0 0
Total 1260446871 986365264 714095684 2168919142
GigabitEthernet4/0/0
Processor 2064128163 2377995992 2465348686 1351290150
Route cache 0 0 0 0
Total 2064128163 2377995992 2465348686 1351290150
Port-channel1
Processor 1469799245 147640677 1711077651 4244227521
Route cache 0 0 0 0
Total 1469799245 147640677 1711077651 4244227521
Loopback0
Processor 0 0 15 0
Route cache 0 0 0 0
Total 0 0 15 0
spt-3-4-ro#
Are ther some explanations for why the Route cache is 0 for all interfaces?
01-31-2003 12:23 AM
Do a check with show ip interface command and see if CEF is disabled. If yes then enable with ip route cache cef command and then do a show interface statistics.
Hope this helps
Maneesh
01-31-2003 12:48 AM
Hello Maneesh,
The show ip interface for GigabitEthernetX/X/X and Port-channer1 shows:
spt-3-4-ro#sh ip interface
GigabitEthernet0/0/0 is up, line protocol is up
Internet protocol processing disabled
GigabitEthernet1/0/0 is up, line protocol is up
Controller0 is up, line protocol is up
GigabitEthernet3/0/0 is up, line protocol is up
GigabitEthernet4/0/0 is up, line protocol is up
Port-channel1 is up, line protocol is up
But the show ip interface for Port-chanel1.X (the vllans) show
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP CEF switching is enabled
/daniel
