Changing CiscoWorks Port 1741 to 80
rpeasah
I edited the apache httpd.conf file and changed the CiscoWorks default port from 1741 to 80. However the login page still references port 1741. Anyone knows how to fix that?
rmushtaq
Level 8
Level 8
Is this for CW2K CD-One 4th Edition and later?. If so, then it's not recommended due to CSCdu37552, which you can see via CCO Bug Toolkit. Changing the port is not as simple as as just editing the httpd.conf file.
rmushtaq
Level 8
Level 8
kemahnken
Having done this based on a client's demands it is not recommended. We adviced the client that not only would the installation be "custom" and not supported by Cisco, upgrades would be difficult as well as ongoing maintenance.
Leave it allow and use a redirector if you don't want people to have to type server:1741 or just create a book mark. It beats the cost and pains of attempting to change it.
