Changing Native VLAN for 3500XL
I want to use VLAN 300 for the native (management) VLAN on a 3500XL. How do I do that on the 3500? I am using .1Q on GigabitEthernet0/1 that is connecting to a 6509. I have setup the port for trunking on the 6509 and specified the vlan as 300 for management.
Silver
Re: Changing Native VLAN for 3500XL
This should do the trick on your trunk interface.
switchport trunk native vlan 300
interface GigabitEthernet0/1
no ip address
shutdown
switchport
switchport mode trunk
end
Hope this helps,
Don
Don,
Do I then create an interface for VLAN300 on the switch or do I used VLAN 1 and then assign the IP address?
Native Vlan is nothing to do with the management vlan. If you want Vlan 300 has the management Vlan, then please create int vlan 300 , and please make sure you shutdown the vlan 1 before doing no shut on the vlan 300
Native vlan is the vlan which is not tagged when trunking is on the port.
Thank you.
95
