Changing RSM trunk in 5500 to dot1q
We have a Cat5500 switch with an RSM installed in slot 7. In order to change the default backplane trunk mode to dot1q (rather than use the ISL default) to the RSM, I was going to issue the following command:
set trunk 7/1 on dot1q
Are there any caveats or issues that I should be aware of when changing this internal trunk? Any advice welcome.
Thanks, Chris
Silver
Re: Changing RSM trunk in 5500 to dot1q
Chris,
An RSM default, and is only capable, of ISL trunking. If you issue your "set trunk" command you should see the following:
Incorrect trunk type specified for module
Allowed trunk type is isl.
Hope this helps you,
Don
Thanks Don, much appreciated.
81
