Webcast-Catalyst9k
Changing the default route for an interface using route-map
All,
I have a vlan over a point to multi point wireless device on a cat 6500
(with router processor) that I need to have default route over one of the
end points on the vlan and not out to the rest of my network. I believe that
I can do this with the a route-map but it does not appear to work. I need
the secondary to make it work with the PMP wireless the two radios can not
see ach other throught the basestation. I need to send all traffic
originating from the 123.123.124.0 network to the 123.123.123.9 address
except for directly connected nets on the 6500.
I have put the following in :
interface VlanXXX
description City Fire Department
ip address 123.123.123.10 255.255.255.252
ip address 123.123.124.1 255.255.255.0 secondary
no ip redirects
no ip unreachables
ip policy route-map 130
route-map 130 permit 10
match ip address 130
set ip default next-hop 123.123.123.9
access-list 130 permit ip any any
Any pointers would be appreciated! What am I missing?
James Gorman
1 REPLY
Re: Changing the default route for an interface using route-map
You are mixing metaphors here.
Policy routing is used to bypass the routing table.
You are using the policy rout to modify the routing table, which it would ignore.
try set ip next-hop 123.123.123.9 in route-map 130
However, this will over-ride everything, including directly connected.
I would do an:
access list 130 deny ip any connected1
access list 130 deny ip any connected2
access list 130 deny ip any connected3
access-list 130 permit ip any any.
This will drop the connected routes into the routing table, where they will be delivered normally. (use the correct networks, rather than connected1)
Policy routes do not affect packets generated by the router without an IP local policy statement, so be sure to test from a separate device.
Good Luck;
Doug
92
