Changing the management VLAN on a layer 2 switch
Suppose I want to change the management VLAN on a layer-2 switch, say a Cat2912XL. I think I can do it something like this.
int VLAN 1
desc Old management VLAN
int VLAN 2
desc New management VLAN
ip address
no shut
ip default-gateway
Now, suppose I want to do it remotely. Problem is that I have to shut down the old VLAN interface before I can bring up the new one. That cuts off the telnet session.
Does anyone have a trick to do this as an atomic operation, i.e. as a single command line? Preferably a solution that does not involve reloading the switch, because it is carrying live traffic. For example, is there any way to creat a command macro, like a multi-line alias?
Kevin Dorrell
Re: Changing the management VLAN on a layer 2 switch
It's OK, I found it. I made a little file containing the lines, called swap-vlan, and put it on my TFTP server. I then copied the file into the flash of the switch, then did a copy flash run, giving swap-vlan as the source file name.
I did a dry run on an unused switch first, to check that the config lines did the job they were supposed to, and didn't cut me off forever. I also did a reload in 10, just in case, and cancelled it once I had contacted the switch in its new position.
Must not forget to copy run start once it is working.
Kevin Dorrell
That's very creative Kevin! I'll rate your for that ;)
