Webcast-Catalyst9k
Channelized DS3 / ISDN PRI - Interface for 72xx
We are trying to use a channelized DS3/PRI for isdn back up. The router platform is a 7206vxr and we purchased the PA-MC-2T3+ to connect. Per Cisco that interface will not create PRI controllers just T1 controllers. The PA-MC-T3 is said to support PRIs on a channelized DS3, but we can find no confirmation on CCO. Has anyone used the PA-MC-T3 for PRIs??
1 REPLY
Silver
Re: Channelized DS3 / ISDN PRI - Interface for 72xx
DS3 is upported in the below cards. Check the link also
PA-T3+, PA-T3+=
One-port clear-channel DS3 port adapter
Recommended for high-performance uplink and trunking applications
PA-2T3+
PA-2T3+=
Two-port clear-channel DS3 port adapter
Recommended for high-density or T3 line aggregation applications
http://www.cisco.com/warp/public/cc/pd/ifaa/pa/prodlit/pods3_ds.htm
664
