Community Member
CHAP authentication problems on PPPoE / DSL
Hi all,
I am experiencing problems with authenticating at an ISP via CHAP on a PPPoE / DSL line. Everything looks like that just the password is wrong, but I checked a couple of user/password combinations with them and get always access denied. PPP/CHAP debug looks fine - see later.
Could there be other reasons for failing with CHAP than just having a wrong user/ password ?
Does anybody know if there are known problems ?
I have a 826 running 12.2(4)YA3 setup for PPPoE:
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
ip address 192.168.36.254 255.255.255.0
no ip proxy-arp
ip tcp adjust-mss 1452
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
dsl operating-mode auto
hold-queue 224 in
interface Dialer1
mtu 1492
ip address negotiated
ip access-group 101 in
ip access-group 102 out
ip inspect internet-out out
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname user@telepac
ppp chap password 7 XXXXXXXX
This is the debug output I get:
*Mar 1 13:08:56: PPPOE: we've got our pado and the pado timer went off
*Mar 1 13:08:56: OUT PADR from PPPoE tunnel
*Mar 1 13:08:56: PPPoE 2573: I PADS L:00b0.c28d.cba2 R:0090.1a10.1091 0/35 AT0
*Mar 1 13:08:56: IN PADS from PPPoE tunnel
*Mar 1 13:08:56: Vi1 PPP: Phase is DOWN, Setup
*Mar 1 13:08:56: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 13:08:56: PPPoE: Virtual Access interface obtained.
*Mar 1 13:08:56: Vi1 PPP: Treating connection as a callout
*Mar 1 13:08:56: Vi1 PPP: Phase is ESTABLISHING, Active Open
*Mar 1 13:08:56: Vi1 PPP: Authorization NOT required
*Mar 1 13:08:56: Vi1 PPP: No remote authentication for call-out
*Mar 1 13:08:56: Vi1 LCP: O CONFREQ [Closed] id 1 len 14
*Mar 1 13:08:56: Vi1 LCP: MRU 1492 (0x010405D4)
*Mar 1 13:08:56: Vi1 LCP: MagicNumber 0xB394DD9D (0x0506B394DD9D)
*Mar 1 13:08:56: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 1 13:08:56: Vi1 LCP: I CONFACK [REQsent] id 1 len 14
*Mar 1 13:08:58: Vi1 LCP: TIMEout: State ACKrcvd
*Mar 1 13:08:58: Vi1 LCP: O CONFREQ [ACKrcvd] id 2 len 14
*Mar 1 13:08:58: Vi1 LCP: MRU 1492 (0x010405D4)
*Mar 1 13:08:58: Vi1 LCP: MagicNumber 0xB394DD9D (0x0506B394DD9D)
*Mar 1 13:08:58: Vi1 LCP: I CONFACK [REQsent] id 2 len 14
*Mar 1 13:08:59: Vi1 LCP: I CONFREQ [ACKrcvd] id 103 len 18
*Mar 1 13:08:59: Vi1 LCP: MRU 1492 (0x010405D4)
*Mar 1 13:09:00: Vi1 LCP: AuthProto PAP (0x0304C023)
*Mar 1 13:09:00: Vi1 LCP: MagicNumber 0x66F686C7 (0x050666F686C7)
*Mar 1 13:09:00: Vi1 LCP: O CONFNAK [ACKrcvd] id 103 len 9
*Mar 1 13:09:00: Vi1 LCP: AuthProto CHAP (0x0305C22305)
*Mar 1 13:09:00: Vi1 LCP: I CONFREQ [ACKrcvd] id 104 len 19
*Mar 1 13:09:00: Vi1 LCP: MRU 1492 (0x010405D4)
*Mar 1 13:09:00: Vi1 LCP: O CONFACK [ACKrcvd] id 104 len 19
*Mar 1 13:09:00: Vi1 LCP: State is Open
*Mar 1 13:09:00: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Mar 1 13:09:00: Vi1 CHAP: I CHALLENGE id 8 len 31 from "dvs-br1"
*Mar 1 13:09:48: Vi1 PPP: Sent CHAP SENDAUTH Request to AAA
*Mar 1 13:09:48: Vi1 PPP: Received SENDAUTH Response from AAA = FAIL
*Mar 1 13:09:00: Vi1 CHAP: O RESPONSE id 8 len 37 from "user@telepac"
***** Here it is:
*Mar 1 13:09:00: Vi1 CHAP: I FAILURE id 8 len 49 msg is "username ou Palavra de acesso incorrecta [()]"
*Mar 1 13:09:00: Vi1 LCP: I TERMREQ [Open] id 105 len 4
*Mar 1 13:09:00: Vi1 LCP: O TERMACK [Open] id 105 len 4
*Mar 1 13:09:00: PPPoE 2573: I PADT L:00b0.c28d.cba2 R:0090.1a10.1091 0/35 AT0
*Mar 1 13:09:00: PPPoE : Shutting down client session
*Mar 1 13:09:00: PPPoE 2573: O PADT L:00b0.c28d.cba2 R:0090.1a10.1091 0/35 AT0
*Mar 1 13:09:00: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 13:09:00: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Mar 1 13:09:00: Vi1 LCP: State is Closed
*Mar 1 13:09:00: Vi1 PPP: Phase is DOWN
Any ideas ?
Markus
1 REPLY
Re: CHAP authentication problems on PPPoE / DSL
There are no known issues like that. It is strictly a authentication issue. ISP is sending authentication failure for user. So ask the ISP for correct username and password combination.
528
