Webcast-Catalyst9k
checking whether an interface is configures as a part of IEEE 802.10
How do i check whether my sub-interface is conigured as a part of IEEE 802.10?
Actually I wanted to assign an ip address to a sub-interface.
1 REPLY
Silver
Re: checking whether an interface is configures as a part of IEE
802.10 is a FDDI spec. Are you sure this is the spec you want to refer to?
Normally 802.10 spec allows for FDDI interfaces to be a trunk/transit for Ethernet and other VLAN types. Mostly done on switches.
Here is a link on 802.10:
http://www.cisco.com/warp/public/537/6.html
What device are you configuring subinterfaces on? Can you share the config portion that you question to this forum can help you more?
Hope this helps you,
Don
94
