Community Member
CI problem or power supply probelm?How can i troubleshoot it?
My 7507 router has the following problem,and i don't know that if it was a malfunctioned CI problem or a power supply problem.How can i trouble it?
Accoriding to my previous experience,the CI model in 7507 router is easy to report the +12V voltage at a low level,and there is something wrong with the ci model.
sh log
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 298 messages logged
Trap logging: level debugging, 307 message lines logged
Logging to 40.112.0.100, 307 message lines logged
--More--
Log Buffer (5000 bytes):
RN: +12 Voltage measured at 11.61
*Aug 1 11:53:56: %CI-4-ENVWARN: +12 Voltage measured at 11.61
*Aug 1 13:14:14: %CI-4-ENVWARN: +12 Voltage measured at 11.61
*Aug 1 17:36:29: %CI-4-ENVWARN: +12 Voltage measured at 11.61
*Aug 1 19:07:47: %CI-4-ENVWARN: +12 Voltage measured at 11.61
*Aug 2 07:43:27: %CI-4-ENVWARN: +12 Voltage measured at 11.61
*Aug 2 22:07:55: %CI-4-ENVWARN: +12 Voltage measured at 11.61
*Aug 3 15:33:02: %CI-4-ENVWARN: +12 Voltage measured at 11.61
*Aug 4 03:06:33: %CI-4-ENVWARN: +12 Voltage measured at 11.61
R2>sh envi
All measured values are normal
R2>sh envi all
Arbiter type 2, backplane type 7507MX (id 4)
Power supply #1 is 700W (id 2), power supply #2 is 700W (id 2)
Active fault conditions: none
Active trip points: none
15 of 15 soft shutdowns remaining before hard shutdown
0123456
Dbus slots: XXX XX
card inlet hotpoint exhaust
RSP(2) 17C/62F 21C/69F 23C/73F
Shutdown temperature source is 'hotpoint' on RSP(2), requested RSP(2)
+12V measured at 11.65
+5V measured at 5.13
-12V measured at -11.89
+24V measured at 22.74
+2.5 reference is 2.47
R2>sh envi ta
Sample Point LowCritical LowWarning HighWarning HighCritical
RSP(2) Inlet 44C/111F 50C/122F
RSP(2) Hotpoint 54C/129F 60C/140F
RSP(2) Exhaust
RSP(3) Inlet 44C/111F 50C/122F
RSP(3) Hotpoint 54C/129F 60C/140F
RSP(3) Exhaust
+12 Voltage 10.90 11.61 12.82 13.38
+5 Voltage 4.61 4.94 5.46 5.70
-12 Voltage -10.15 -10.76 -13.25 -13.86
+24 Voltage 20.38 21.51 26.42 27.65
2.5 Reference 2.43 2.51
Shutdown boards at 70C/158F
Shutdown power supplies at 76C/168F
Restart after shutdown below 40C/104F
R2>sh envi last
RSP(2) Inlet previously measured at 15C/59F
RSP(2) Hotpoint previously measured at 19C/66F
RSP(2) Exhaust previously measured at 21C/69F
+12 Voltage previously measured at 11.70
+5 Voltage previously measured at 5.13
-12 Voltage previously measured at -11.89
+24 Voltage previously measured at 22.74
1 REPLY
Bronze
Re: CI problem or power supply probelm?How can i troubleshoot it
You'll probably want to contact your tac engineers on this one.
174
