04-29-2002 03:33 AM - edited 03-01-2019 09:32 PM
I have configured a 1605-R box (IOS 12.2.8T1) to establish a PPPOE session to Deutsche Telekom (German Carrier) via T-DSL . Everything is working fine, but i miss two essential Features:
1. Dial-on-Demand Routing
2. Dialer Idle-Timeout
Therefore i have to open and close the PPPOE Session manually by CLI.
Are there any plans to implement the two functions described above?
Dirk
04-29-2002 08:15 AM
You should be able to specify the idle timeout under the virtual-template or dialer interface, whichever you are using for the PPPoE functionality. Not sure what other features you want with "Dial on Demand Routing". However, I would think that any session being timed out will simply cause the client to re-connect immediately, so I'm not sure how effective a timer will be.
04-30-2002 12:18 AM
Because my ISP charges are based on the amount of time the automatic PPPoE Client reconnect ist exactly the problem. Dial-on-Demand Routing for PPPoE Client is implemented in the Cisco 8xx and SOHO77/78:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/827/827rlnts/820feat.htm#xtocid40
I need the same function for my 1605-R box.
04-30-2002 08:54 AM
04-30-2002 04:01 PM
Sorry,
I think thats the right syntax, isn't it?
pppoe-client dial-pool-number number [dial-on-demand]
Problem is that the [dial-on-demand] keyword is not available on my 1605-R with 12.2.8T
05-01-2002 01:09 PM
I don't see that option as available:
