Webcast-Catalyst9k
Cisco 1720 ISDN BRI to Bay ARN router: chap problem
Hi, we can connect with Bay router to our Cisco with no problem. But the other way around gives problems. It seems he connects but then he disconnects immediately. Can't give config of Bay as it is at client side. But hereby the log on our cisco router. According to me it's something with chap authenticaton but not sure. Anybody any idea? Where can you find info on how to interpret this log? THANKS
6w6d: ISDN BR0: TX -> RELEASE pd = 8 callref = 0x75
6w6d: Cause i = 0x8090 - Normal call clearing
6w6d: Vi1 IPCP: State is Closed
6w6d: Vi1 CDPCP: State is Closed
6w6d: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0xF5
6w6d: Vi1 PPP: Missed link down notification
6w6d: Vi1 PPP: Phase is TERMINATING
6w6d: Vi1 LCP: State is Closed
6w6d: Vi1 PPP: Phase is DOWN
6w6d: ISDN BR0: TX -> SETUP pd = 8 callref = 0x76
6w6d: Bearer Capability i = 0x8890
6w6d: Channel ID i = 0x83
6w6d: Called Party Number i = 0x80, 'xxxxxxx', Plan:Unknown, Type:Unk
nown
6w6d: ISDN BR0: RX <- SETUP_ACK pd = 8 callref = 0xF6
6w6d: Channel ID i = 0x8A
6w6d: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0xF6
6w6d: ISDN BR0: RX <- CONNECT pd = 8 callref = 0xF6
6w6d: Display i = 'NO', 0x20, 'NAME', 0x20, 'AVAILABLE'
6w6d: Connected Number i = 0x218331353236303
6w6d: ISDN BR0: TX -> CONNECT_ACK pd = 8 callref = 0x76
6w6d: %LINK-3-UPDOWN: Interface BRI0:2, changed state to up
6w6d: BR0:2 PPP: Treating connection as a callout
6w6d: BR0:2 PPP: Phase is ESTABLISHING, Active Open
6w6d: BR0:2 PPP: No remote authentication for call-out
6w6d: BR0:2 CHAP: Using alternate hostname xxxxxxx
6w6d: BR0:2 LCP: O CONFREQ [Closed] id 159 len 30
6w6d: BR0:2 LCP: MagicNumber 0xFE050022 (0x0506FE050022)
6w6d: BR0:2 LCP: MRRU 1524 (0x110405F4)
6w6d: BR0:2 LCP: EndpointDisc 1 Local (0x1310016B62635F616363656E74757265)
6w6d: BR0:2 LCP: I CONFACK [REQsent] id 159 len 30
6w6d: BR0:2 LCP: I CONFREQ [ACKrcvd] id 1 len 32
6w6d: BR0:2 LCP: MRRU 1500 (0x110405DC)
6w6d: BR0:2 LCP: EndpointDisc 3 0100.a2f8.e4a9 (0x1309030100A2F8E4A9)
6w6d: BR0:2 LCP: AuthProto CHAP (0x0305C22305)
6w6d: BR0:2 LCP: MagicNumber 0x67D8E24C (0x050667D8E24C)
6w6d: BR0:2 LCP: LinkDiscriminator 4672 (0x17041240)
6w6d: BR0:2 LCP: O CONFREJ [ACKrcvd] id 1 len 8
6w6d: BR0:2 LCP: I CONFREQ [ACKrcvd] id 2 len 28
6w6d: BR0:2 LCP: O CONFACK [ACKrcvd] id 2 len 28
6w6d: BR0:2 LCP: State is Open
Bronze
Re: Cisco 1720 ISDN BRI to Bay ARN router: chap problem
Hi, I don't see anything wrong here, but you need to add "debug ppp authentication" to the debugging that you are already doing, and post the results.
Mark
The debug you have posted may not be full. But as you can see from the PPP negotiatioin log that bay router wants to do CHAP with cisco router. But does the cisco router configured for that too? We need to see the running config from the cisco router as well. So post the config with the debug for following for a call to get the clear idea. Also capture the debug till isdn connection disconnects.
debug ppp negotiation
debug dialer
debug isnd q931
139
