Cisco 1720 VWIC supports ISDN PRI Data?
Is it possible for the 1720 to support ISDN PRI Data from on of the Voice WAN Interface Card?
Re: Cisco 1720 VWIC supports ISDN PRI Data?
Yes, if its a data only circuit, then yes you can use that for ISDN PRI.
Which WIC or VWIC would you use? I put the question to a colleague the reply was that the V/WICs supported by the 1720 can't do ISDN PRI. The link http://www.cisco.com/en/US/partner/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml confirms this.
228
