Webcast-Catalyst9k
Cisco 1721 with 1 BRI dial into Cisco 2612 with PRI-Adapter
Hi, i am having some trouble configuring a 1721 with 1 BRI to dial into a 2612 with a PRI adapter. It seems that something is going wrong during PPP on the 2612, authentication is OK and it gets a route to install via Cisco AV-Pair from our Radius (ACS). It installs the route and just deletes it again after that. With the same config on the 1721 i can dial into a Cisco 3660 who talks to the same Radius-Server. Everything is fine then ...
I have logs of ppp negotiation, ppp authentication and radius from the 2612 and 3660. Maybe you can help me to find out what the problem is.....
Here come the logs...
hmmm, problem with 10000 charcters, I´ll post the logs as follow up to this posting ....
The config on the 1721 is always the same, and both the 2612 and 3660 authenticate using the same Radius-Server and user credentials....
Thank you ...
Re: Cisco 1721 with 1 BRI dial into Cisco 2612 with PRI-Adapter
Here´s the log of the 2612:
20:16:124554051584: %LINK-3-UPDOWN: Interface Serial1/0:19, changed state to up
20:16:126701535205: Se1/0:19 PPP: Treating connection as a callin
20:16:126712215284: Se1/0:19 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 1 load]
20:16:126714682812: Se1/0:19 LCP: State is Listen
20:16:31: Se1/0:19 LCP: I CONFREQ [Listen] id 1 len 24
20:16:31: Se1/0:19 LCP: MagicNumber 0x0D86B3B6 (0x05060D86B3B6)
20:16:31: Se1/0:19 LCP: MRRU 1524 (0x110405F4)
20:16:31: Se1/0:19 LCP: EndpointDisc 1 RoutFW3 (0x130A01526F7574465733)
20:16:31: Se1/0:19 LCP: O CONFREQ [Listen] id 2 len 35
20:16:31: Se1/0:19 LCP: AuthProto MS-CHAP (0x0305C22380)
20:16:31: Se1/0:19 LCP: MagicNumber 0x0670436E (0x05060670436E)
20:16:31: Se1/0:19 LCP: EndpointDisc 1 RoutStA37-RAS (0x131001526F757453744133372D524153)
20:16:31: Se1/0:19 LCP: O CONFACK [Listen] id 1 len 24
20:16:31: Se1/0:19 LCP: I CONFACK [ACKsent] id 2 len 35
20:16:31: Se1/0:19 LCP: State is Open
20:16:31: Se1/0:19 PPP: Phase is AUTHENTICATING, by this end [0 sess, 0 load]
20:16:31: Se1/0:19 MS-CHAP: O CHALLENGE id 2 len 26 from "RoutStA37-RAS"
20:16:31: Se1/0:19 MS-CHAP: I RESPONSE id 2 len 61 from "RoutFW3"
20:16:31: RADIUS: ustruct sharecount=1
20:16:31: Radius: radius_port_info() success=1 radius_nas_port=1
20:16:31: RADIUS: Initial Transmit Serial1/0:19 id 170 172.17.2.250:1812, Access-Request, len 145
20:16:31: Attribute 4 6 AC132406
20:16:31: Attribute 5 6 00004E33
20:16:31: Attribute 61 6 00000002
20:16:31: Attribute 1 9 526F7574
20:16:31: Attribute 31 12 32333134
20:16:31: Attribute 26 16 000001370B0AA830
20:16:31: Attribute 26 58 0000013701340201
20:16:31: Attribute 6 6 00000002
20:16:31: Attribute 7 6 00000001
20:16:31: RADIUS: Received from id 170 172.17.2.250:1812, Access-Accept, len 99
20:16:31: Attribute 26 61 0000000901376970
20:16:31: Attribute 8 6 0AFFFF02
20:16:31: RADIUS: cisco AVPair "ip:route=172.16.37.224 255.255.255.224 10.255.255.2 1" not applied for lcp
20:16:31: Se1/0:19 MS-CHAP: O SUCCESS id 2 len 4
20:16:31: Se1/0:19 PPP: Phase is VIRTUALIZED [0 sess, 0 load]
20:16:31: RADIUS: cisco AVPair "ip:route=172.16.37.224 255.255.255.224 10.255.255.2 1" not applied for multilink
20:16:31: Vi5 PPP: Phase is DOWN, Setup [0 sess, 0 load]
20:16:31: Vi5 PPP: No remote authentication for call-in
20:16:31: Vi5 PPP: Phase is ESTABLISHING [0 sess, 0 load]
20:16:31: Vi5 CCP: Compression already closed
20:16:31: Vi5 CCP: Re-Syncing history using legacy method
20:16:31: %LINK-3-UPDOWN: Interface Virtual-Access5, changed state to up
20:16:31: Vi5 PPP: Treating connection as a callin
20:16:31: Vi5 LCP: State is Listen
20:16:31: Vi5 PPP: Phase is UP [0 sess, 0 load]
20:16:31: RADIUS: Authorize IP address 10.255.255.2
20:16:31: Vi5 IPCP: O CONFREQ [Closed] id 1 len 16
20:16:31: Vi5 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
20:16:31: Vi5 IPCP: Address 172.19.36.6 (0x0306AC132406)
20:16:31: RADIUS: cisco AVPair "ip:route=172.16.37.224 255.255.255.224 10.255.255.2 1" not applied for ccp
20:16:31: Vi5 CCP: O CONFREQ [Closed] id 1 len 10
20:16:31: Vi5 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
20:16:31: Vi5 MLP: Added first link Se1/0:19 to bundle RoutFW3
20:16:31: Se1/0:19 IPCP: MLP bundle interface is built, process packets now
20:16:31: Se1/0:19 IPCP: Redirect packet to Vi5
20:16:31: Vi5 IPCP: I CONFREQ [REQsent] id 7 len 16
20:16:31: Vi5 IPCP: Address 0.0.0.0 (0x030600000000)
20:16:31: Vi5 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 0.0.0.0
20:16:31: Vi5 AAA/AUTHOR/IPCP: Done. Her address 0.0.0.0, we want 10.255.255.2
20:16:31: Vi5 IPCP: O CONFNAK [REQsent] id 7 len 10
20:16:31: Vi5 IPCP: Address 10.255.255.2 (0x03060AFFFF02)
20:16:31: Se1/0:19 CCP: MLP bundle interface is built, process packets now
20:16:31: Se1/0:19 CCP: Redirect packet to Vi5
20:16:31: Vi5 CCP: I CONFREQ [REQsent] id 14 len 10
20:16:31: Vi5 CCP: O CONFACK [REQsent] id 14 len 10
20:16:31: Vi5 IPCP: I CONFACK [REQsent] id 1 len 16
20:16:31: Vi5 CCP: I CONFACK [ACKsent] id 1 len 10
20:16:31: Vi5 CCP: State is Open
20:16:31: Vi5 CCP: ppp_hwcomp_open: no h/w
20:16:31: Vi5 IPCP: I CONFREQ [ACKrcvd] id 8 len 16
20:16:31: Vi5 AAA/AUTHOR/IPCP: Start. Her address 10.255.255.2, we want 10.255.255.2
20:16:31: Vi5 AAA/AUTHOR/IPCP: Done. Her address 10.255.255.2, we want 10.255.255.2
20:16:31: Vi5 IPCP: O CONFACK [ACKrcvd] id 8 len 16
20:16:31: Vi5 IPCP: State is Open
20:16:31: RADIUS: ustruct sharecount=3
20:16:31: RADIUS: Initial Transmit Serial1/0:19 id 171 172.17.2.250:1813, Accounting-Request, len 116
20:16:31: Attribute 40 6 00000001
20:16:31: Attribute 45 6 00000001
20:16:31: Attribute 44 10 30303030
20:16:31: Attribute 51 6 00000001
20:16:31: Attribute 50 5 32300008
20:16:31: Attribute 41 6 00000000
20:16:31: Vi5 AAA/AUTHOR/IP: authorization failed
20:16:31: Vi5 IPCP: O TERMREQ [Open] id 2 len 4
20:16:31: Vi5 PPP: Phase is TERMINATING [0 sess, 0 load]
20:16:31: Di1 IPCP: Install route to 10.255.255.2
20:16:31: Di1 IPCP: Remove route to 10.255.255.2
20:16:31: RADIUS: Received from id 171 172.17.2.250:1813, Accounting-response, len 20
20:16:31: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:32: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:19, changed state to up
20:16:32: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access5, changed state to up
20:16:32: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:33: Vi5 IPCP: TIMEout: State TERMsent
20:16:33: Vi5 IPCP: O TERMREQ [TERMsent] id 3 len 4
20:16:33: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:34: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:35: Vi5 IPCP: TIMEout: State TERMsent
20:16:35: Vi5 IPCP: State is Closed
20:16:35: %ISDN-6-CONNECT: Interface Serial1/0:19 is now connected to 2314765538 RoutFW3
20:16:36: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:38: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:40: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:42: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:44: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:46: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:48: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
20:16:50: Vi5 IPCP: PPP phase is TERMINATING, discarding packet
And here´s the log of the 3660:
1w1d: %LINK-3-UPDOWN: Interface Serial1/1:6, changed state to up
1w1d: Se1/1:6 PPP: Using dialer call direction
1w1d: Se1/1:6 PPP: Treating connection as a callin
1w1d: Se1/1:6 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 1 load]
1w1d: Se1/1:6 LCP: State is Listen
1w1d: RADIUS: ustruct sharecount=3
1w1d: Radius: radius_port_info() success=1 radius_nas_port=1
1w1d: RADIUS: Initial Transmit Serial1/1:11 id 45 172.17.2.250:1813, Accounting-Request, len 142
1w1d: Attribute 4 6 AC110201
1w1d: Attribute 5 6 00004E8F
1w1d: Attribute 61 6 00000002
1w1d: Attribute 1 9 76353136
1w1d: Attribute 31 7 31303230
1w1d: Attribute 40 6 00000003
1w1d: Attribute 45 6 00000001
1w1d: Attribute 6 6 00000002
1w1d: Attribute 44 10 30303030
1w1d: Attribute 7 6 00000001
1w1d: Attribute 51 6 00000001
1w1d: Attribute 50 6 33313600
1w1d: Attribute 8 6 AC122A77
1w1d: Attribute 42 6 0001153F
1w1d: Attribute 43 6 000DD6C3
1w1d: Attribute 47 6 00000362
1w1d: Attribute 48 6 0000036F
1w1d: Attribute 46 6 00001725
1w1d: Attribute 41 6 00000000
1w1d: RADIUS: Received from id 45 172.17.2.250:1813, Accounting-response, len 20
1w1d: Se1/1:6 LCP: I CONFREQ [Listen] id 1 len 24
1w1d: Se1/1:6 LCP: MagicNumber 0x0D8B9D9A (0x05060D8B9D9A)
1w1d: Se1/1:6 LCP: MRRU 1524 (0x110405F4)
1w1d: Se1/1:6 LCP: EndpointDisc 1 RoutFW3 (0x130A01526F7574465733)
1w1d: Se1/1:6 LCP: O CONFREQ [Listen] id 16 len 32
1w1d: Se1/1:6 LCP: AuthProto MS-CHAP (0x0305C22380)
1w1d: Se1/1:6 LCP: MagicNumber 0x304C0DCD (0x0506304C0DCD)
1w1d: Se1/1:6 LCP: EndpointDisc 1 RoutEWAHL1 (0x130D01526F7574455741484C31)
1w1d: Se1/1:6 LCP: O CONFACK [Listen] id 1 len 24
1w1d: Se1/1:6 LCP: I CONFACK [ACKsent] id 16 len 32
1w1d: Se1/1:6 LCP: State is Open
1w1d: Se1/1:6 PPP: Phase is AUTHENTICATING, by this end [0 sess, 1 load]
1w1d: Se1/1:6 MS-CHAP: O CHALLENGE id 14 len 23 from "RoutEWAHL1"
1w1d: Se1/1:6 MS-CHAP: I RESPONSE id 14 len 61 from "RoutFW3"
1w1d: RADIUS: ustruct sharecount=1
1w1d: RADIUS: added cisco VSA 2 len 11 "Serial1/1:6"
1w1d: RADIUS: Initial Transmit Serial1/1:6 id 46 172.17.2.250:1812, Access-Request, len 162
1w1d: Attribute 5 6 00004E8A
1w1d: Attribute 26 19 00000009020D5365
1w1d: Attribute 1 9 526F7574
1w1d: Attribute 31 10 30343736
1w1d: Attribute 26 16 000001370B0A10F1
1w1d: Attribute 26 58 0000013701340E01
1w1d: RADIUS: Received from id 46 172.17.2.250:1812, Access-Accept, len 99
1w1d: Attribute 26 61 0000000901376970
1w1d: Attribute 8 6 0AFFFF02
1w1d: RADIUS: cisco AVPair "ip:route=172.16.37.224 255.255.255.224 10.255.255.2 1" not applied for lcp
1w1d: Se1/1:6 MS-CHAP: O SUCCESS id 14 len 4
1w1d: Se1/1:6 PPP: Phase is VIRTUALIZED [0 sess, 1 load]
1w1d: RADIUS: cisco AVPair "ip:route=172.16.37.224 255.255.255.224 10.255.255.2 1" not applied for multilink
1w1d: Vi22 PPP: Phase is DOWN, Setup [0 sess, 1 load]
1w1d: Vi22 PPP: No remote authentication for call-in
1w1d: Vi22 CCP: Compression already closed
1w1d: Vi22 CCP: Re-Syncing history using legacy method
1w1d: %LINK-3-UPDOWN: Interface Virtual-Access22, changed state to up
1w1d: Vi22 PPP: Using dialer call direction
1w1d: Vi22 PPP: Treating connection as a callin
1w1d: Vi22 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 1 load]
1w1d: Vi22 LCP: State is Listen
1w1d: Vi22 PPP: Phase is UP [0 sess, 1 load]
1w1d: RADIUS: Authorize IP address 10.255.255.2
1w1d: Vi22 IPCP: O CONFREQ [Closed] id 1 len 16
1w1d: Vi22 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
1w1d: Vi22 IPCP: Address 172.17.2.1 (0x0306AC110201)
1w1d: RADIUS: cisco AVPair "ip:route=172.16.37.224 255.255.255.224 10.255.255.2 1" not applied for ccp
1w1d: Vi22 CCP: O CONFREQ [Closed] id 1 len 10
1w1d: Vi22 CCP: MS-PPC supported bits 0x01000041 (0x120601000041)
1w1d: Vi22 MLP: Added first link Se1/1:6 to bundle RoutFW3
1w1d: Vi22 IPCP: I CONFREQ [REQsent] id 21 len 16
1w1d: Vi22 IPCP: Address 0.0.0.0 (0x030600000000)
1w1d: Vi22 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 0.0.0.0
1w1d: Vi22 AAA/AUTHOR/IPCP: Done. Her address 0.0.0.0, we want 10.255.255.2
1w1d: Vi22 IPCP: O CONFNAK [REQsent] id 21 len 10
1w1d: Vi22 IPCP: Address 10.255.255.2 (0x03060AFFFF02)
1w1d: Vi22 CCP: I CONFREQ [REQsent] id 15 len 10
1w1d: Vi22 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
1w1d: Vi22 CCP: O CONFNAK [REQsent] id 15 len 10
1w1d: Vi22 CCP: MS-PPC supported bits 0x00000041 (0x120600000041)
1w1d: Vi22 IPCP: I CONFACK [REQsent] id 1 len 16
1w1d: Vi22 CCP: I CONFNAK [REQsent] id 1 len 10
1w1d: Vi22 CCP: O CONFREQ [REQsent] id 2 len 10
1w1d: Vi22 IPCP: I CONFREQ [ACKrcvd] id 22 len 16
1w1d: Vi22 AAA/AUTHOR/IPCP: Start. Her address 10.255.255.2, we want 10.255.255.2
1w1d: Vi22 AAA/AUTHOR/IPCP: Done. Her address 10.255.255.2, we want 10.255.255.2
1w1d: Vi22 IPCP: O CONFACK [ACKrcvd] id 22 len 16
1w1d: Vi22 IPCP: State is Open
1w1d: Vi22 CCP: I CONFREQ [REQsent] id 16 len 10
1w1d: Vi22 CCP: O CONFNAK [REQsent] id 16 len 10
1w1d: Vi22 CCP: I CONFACK [REQsent] id 2 len 10
1w1d: RADIUS: Initial Transmit Serial1/1:6 id 47 172.17.2.250:1813, Accounting-Request, len 115
1w1d: Attribute 40 6 00000001
1w1d: Attribute 50 6 33333400
1w1d: Di1 IPCP: Install route to 10.255.255.2
1w1d: RADIUS: Received from id 47 172.17.2.250:1813, Accounting-response, len 20
Problem solved !!
The 2612 was running IOS with Remote Access Server feature Set, updated to IP Feature-Set and it now works ....
121
