10-21-2010 06:17 PM - edited 03-03-2019 06:06 AM
Hi everybody,
I have this problem: I have two Cisco 1801 (RT1 AND RT2) with this IOS, c180x-advipservicesk9-mz.123-8.YI3
A litte intro: the routers are on my desk, so not in production, not connected to other devices or ADSL pots. I'm connected through the console cable.
I bought them of second hand. I turned RT1 on, I put a configuration i had on another router in production for using it to connect to the Internet and after that R1 got stuck. When I reboot it, it stops at ATM0 initilization. From that moment on I had not been able to enter into even user mode anymore and even into rommon it gets stuck.
When I put the flash on RT2, it got stuck as well! And it didn t even let me enter into rommon! I re-put the original flash of RT2, VIRGIN, and............. IT DIDN T WORK AGAIN!!
I thought instantly of a faulty couples of routers.
but I was wondering if it could be possible that the configuration blocks the booting process as the ATM0 is looking for a connection on adsl port...
it sounds a little bit strange thou... as with the virgin flash they should be able to work!
Thanks.
this is the conf:
vvvvv# sh run
Building configuration...
Current configuration : 7982 bytes
version 12.4
service password-encryption
hostname vvvvv
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret *removed*
no aaa new-model
crypto pki trustpoint TP-self-signed-*removed*
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-*removed*
revocation-check none
rsakeypair TP-self-signed-*removed*
crypto pki certificate chain TP-self-signed-*removed*
certificate self-signed 01
*removed*
quit
dot11 syslog
ip cef
no ip domain lookup
ip domain name yourdomain.com
username tswadmin secret *removed*
username test password *removed*
crypto isakmp policy 5
encr 3des
authentication pre-share
group 2
crypto isakmp key *removed* address *removed*
crypto ipsec transform-set 3DES-SHA1 esp-3des esp-sha-hmac
crypto map VPN 10 ipsec-isakmp
set peer *removed*
set transform-set 3DES-SHA1
set pfs group2
match address ACL_1
archive
log config
hidekeys
interface ATM0
description Interface to Internet
no ip address
ip virtual-reassembly
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
dsl enable-training-log
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address *removed*
ip nat inside
duplex auto
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
no ip address
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip accounting output-packets
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
no cdp enable
ppp authentication pap callin
ppp chap hostname *removed*
ppp chap password *removed*
ppp pap sent-username *removed*
ppp ipcp route default
crypto map VPN
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 172.18.101.0 255.255.255.0 172.18.101.254
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map nonat interface Dialer1 overload
ip access-list extended ACL_1
permit ip *removed*
access-list 110 remark nonat excemption for Ipsec
access-list 110 deny *removed*
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps config-copy
snmp-server enable traps entity
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps pw vc
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server host *removed* public
no cdp run
route-map nonat permit 10
match ip address 110
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
10-21-2010 07:29 PM
What is the size of your CF?
10-21-2010 08:02 PM
Thanks for replying.
64MB. I already tried to format both and put IOS again but same as before.
10-21-2010 08:10 PM
Ok the CF may not be the culprit ... Have you tried booting without the config? How about if you've tried a different IOS version.
10-21-2010 08:26 PM
Having formatted the CFs, shouldn't I have lost all configuration included?
I was planning to download a new IOS now.
10-21-2010 09:11 PM
one is also doing a strange noise, like if there was a 'click' inside every 3 or 4 seconds.
thanks.
