Cisco 2503 routing problems
I have two cisco 2503's (I know, I know, "Update for cripes sakes!") and am having problems routing between two of my serial interfaces. I am using class "C" addresses of 192.168.0.1 and .2 255.255.255.0 between them (testlab with DCE/DTE cables). I have "no shut" the interfaces and setup "clock rate 64000" on the DCE side. The paste below is all I can get out of it though:
Serial1 is down, line protocol is down
Hardware is HD64570
Internet address is 192.168.0.2/24
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input never, output never, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 142 interface resets
0 carrier transitions
DCD=up DSR=up DTR=down RTS=down CTS=up
Thank you for any assistance,
Lost in routing hell
Re: Cisco 2503 routing problems
Can you paste output of "show controllers serial 0" on either ends.
Sure can, I'd be glad to and here they are for all serial links/each router:
Router - Houston-top#sh cont s 0
HD unit 0, idb = 0xBC528, driver structure at 0xC17C0
buffer size 1524 HD unit 0, V.35 DTE cable
cpb = 0xE2, eda = 0x4140, cda = 0x4000
RX ring with 16 entries at 0xE24000
00 bd_ptr=0x4000 pak=0x0C4578 ds=0xE2E4C8 status=80 pak_size=0
01 bd_ptr=0x4014 pak=0x0C4394 ds=0xE2DE0C status=80 pak_size=0
02 bd_ptr=0x4028 pak=0x0C41B0 ds=0xE2D750 status=80 pak_size=0
03 bd_ptr=0x403C pak=0x0C3FCC ds=0xE2D094 status=80 pak_size=0
04 bd_ptr=0x4050 pak=0x0C3DE8 ds=0xE2C9D8 status=80 pak_size=0
05 bd_ptr=0x4064 pak=0x0C3C04 ds=0xE2C31C status=80 pak_size=0
06 bd_ptr=0x4078 pak=0x0C3A20 ds=0xE2BC60 status=80 pak_size=0
07 bd_ptr=0x408C pak=0x0C383C ds=0xE2B5A4 status=80 pak_size=0
08 bd_ptr=0x40A0 pak=0x0C3658 ds=0xE2AEE8 status=80 pak_size=0
09 bd_ptr=0x40B4 pak=0x0C3474 ds=0xE2A82C status=80 pak_size=0
10 bd_ptr=0x40C8 pak=0x0C3290 ds=0xE2A170 status=80 pak_size=0
11 bd_ptr=0x40DC pak=0x0C30AC ds=0xE29AB4 status=80 pak_size=0
12 bd_ptr=0x40F0 pak=0x0C2EC8 ds=0xE293F8 status=80 pak_size=0
13 bd_ptr=0x4104 pak=0x0C2CE4 ds=0xE28D3C status=80 pak_size=0
14 bd_ptr=0x4118 pak=0x0C2B00 ds=0xE28680 status=80 pak_size=0
15 bd_ptr=0x412C pak=0x0C291C ds=0xE27FC4 status=80 pak_size=0
16 bd_ptr=0x4140 pak=0x0C2738 ds=0xE27908 status=80 pak_size=0
cpb = 0xE2, eda = 0x4800, cda = 0x4800
TX ring with 1 entries at 0xE24800
00 bd_ptr=0x4800 pak=0x000000 ds=0x000000 status=80 pak_size=0
01 bd_ptr=0x4814 pak=0x000000 ds=0x000000 status=80 pak_size=0
0 missed datagrams, 0 overruns
0 bad datagram encapsulations, 0 memory errors
0 transmitter underruns
0 residual bit errors
Houston-top#sh cont s 1
HD unit 1, idb = 0xC56C8, driver structure at 0xCA960
buffer size 1524 HD unit 1, V.35 DCE cable, clockrate 56000
cpb = 0xE3, eda = 0x2940, cda = 0x2800
RX ring with 16 entries at 0xE32800
00 bd_ptr=0x2800 pak=0x0CD718 ds=0xE3C60C status=80 pak_size=0
01 bd_ptr=0x2814 pak=0x0CD534 ds=0xE3BF50 status=80 pak_size=0
02 bd_ptr=0x2828 pak=0x0CD350 ds=0xE3B894 status=80 pak_size=0
03 bd_ptr=0x283C pak=0x0CD16C ds=0xE3B1D8 status=80 pak_size=0
04 bd_ptr=0x2850 pak=0x0CCF88 ds=0xE3AB1C status=80 pak_size=0
05 bd_ptr=0x2864 pak=0x0CCDA4 ds=0xE3A460 status=80 pak_size=0
06 bd_ptr=0x2878 pak=0x0CCBC0 ds=0xE39DA4 status=80 pak_size=0
07 bd_ptr=0x288C pak=0x0CC9DC ds=0xE396E8 status=80 pak_size=0
08 bd_ptr=0x28A0 pak=0x0CC7F8 ds=0xE3902C status=80 pak_size=0
09 bd_ptr=0x28B4 pak=0x0CC614 ds=0xE38970 status=80 pak_size=0
10 bd_ptr=0x28C8 pak=0x0CC430 ds=0xE382B4 status=80 pak_size=0
11 bd_ptr=0x28DC pak=0x0CC24C ds=0xE37BF8 status=80 pak_size=0
12 bd_ptr=0x28F0 pak=0x0CC068 ds=0xE3753C status=80 pak_size=0
13 bd_ptr=0x2904 pak=0x0CBE84 ds=0xE36E80 status=80 pak_size=0
14 bd_ptr=0x2918 pak=0x0CBCA0 ds=0xE367C4 status=80 pak_size=0
15 bd_ptr=0x292C pak=0x0CBABC ds=0xE36108 status=80 pak_size=0
16 bd_ptr=0x2940 pak=0x0CB8D8 ds=0xE35A4C status=80 pak_size=0
cpb = 0xE3, eda = 0x3000, cda = 0x3000
TX ring with 1 entries at 0xE33000
00 bd_ptr=0x3000 pak=0x000000 ds=0xE40AF8 status=80 pak_size=22
01 bd_ptr=0x3014 pak=0x0EB84C ds=0xE40AF8 status=80 pak_size=22
Router Austin-bottom#sh cont s 0
HD unit 0, idb = 0xBC0E4, driver structure at 0xC0F08
00 bd_ptr=0x4000 pak=0x0C3C60 ds=0xE2E4C8 status=80 pak_size=0
01 bd_ptr=0x4014 pak=0x0C3A80 ds=0xE2DE0C status=80 pak_size=0
02 bd_ptr=0x4028 pak=0x0C38A0 ds=0xE2D750 status=80 pak_size=0
03 bd_ptr=0x403C pak=0x0C36C0 ds=0xE2D094 status=80 pak_size=0
04 bd_ptr=0x4050 pak=0x0C34E0 ds=0xE2C9D8 status=80 pak_size=0
05 bd_ptr=0x4064 pak=0x0C3300 ds=0xE2C31C status=80 pak_size=0
06 bd_ptr=0x4078 pak=0x0C3120 ds=0xE2BC60 status=80 pak_size=0
07 bd_ptr=0x408C pak=0x0C2F40 ds=0xE2B5A4 status=80 pak_size=0
08 bd_ptr=0x40A0 pak=0x0C2D60 ds=0xE2AEE8 status=80 pak_size=0
09 bd_ptr=0x40B4 pak=0x0C2B80 ds=0xE2A82C status=80 pak_size=0
10 bd_ptr=0x40C8 pak=0x0C29A0 ds=0xE2A170 status=80 pak_size=0
11 bd_ptr=0x40DC pak=0x0C27C0 ds=0xE29AB4 status=80 pak_size=0
12 bd_ptr=0x40F0 pak=0x0C25E0 ds=0xE293F8 status=80 pak_size=0
13 bd_ptr=0x4104 pak=0x0C2400 ds=0xE28D3C status=80 pak_size=0
14 bd_ptr=0x4118 pak=0x0C2220 ds=0xE28680 status=80 pak_size=0
15 bd_ptr=0x412C pak=0x0C2040 ds=0xE27FC4 status=80 pak_size=0
16 bd_ptr=0x4140 pak=0x0C1E60 ds=0xE27908 status=80 pak_size=0
cpb = 0xE2, eda = 0x4814, cda = 0x4814
TX ring with 2 entries at 0xE24800
00 bd_ptr=0x4800 pak=0x000000 ds=0xE40D58 status=80 pak_size=22
02 bd_ptr=0x4828 pak=0x000000 ds=0x000000 status=80 pak_size=0
Austin-bottom#sh cont s 1
HD unit 1, idb = 0xC4D8C, driver structure at 0xC9BB0
00 bd_ptr=0x2800 pak=0x0CC908 ds=0xE3C60C status=80 pak_size=0
01 bd_ptr=0x2814 pak=0x0CC728 ds=0xE3BF50 status=80 pak_size=0
02 bd_ptr=0x2828 pak=0x0CC548 ds=0xE3B894 status=80 pak_size=0
03 bd_ptr=0x283C pak=0x0CC368 ds=0xE3B1D8 status=80 pak_size=0
04 bd_ptr=0x2850 pak=0x0CC188 ds=0xE3AB1C status=80 pak_size=0
05 bd_ptr=0x2864 pak=0x0CBFA8 ds=0xE3A460 status=80 pak_size=0
06 bd_ptr=0x2878 pak=0x0CBDC8 ds=0xE39DA4 status=80 pak_size=0
07 bd_ptr=0x288C pak=0x0CBBE8 ds=0xE396E8 status=80 pak_size=0
08 bd_ptr=0x28A0 pak=0x0CBA08 ds=0xE3902C status=80 pak_size=0
09 bd_ptr=0x28B4 pak=0x0CB828 ds=0xE38970 status=80 pak_size=0
10 bd_ptr=0x28C8 pak=0x0CB648 ds=0xE382B4 status=80 pak_size=0
11 bd_ptr=0x28DC pak=0x0CB468 ds=0xE37BF8 status=80 pak_size=0
12 bd_ptr=0x28F0 pak=0x0CB288 ds=0xE3753C status=80 pak_size=0
13 bd_ptr=0x2904 pak=0x0CB0A8 ds=0xE36E80 status=80 pak_size=0
14 bd_ptr=0x2918 pak=0x0CAEC8 ds=0xE367C4 status=80 pak_size=0
15 bd_ptr=0x292C pak=0x0CACE8 ds=0xE36108 status=80 pak_size=0
16 bd_ptr=0x2940 pak=0x0CAB08 ds=0xE35A4C status=80 pak_size=0
TX ring with 2 entries at 0xE33000
00 bd_ptr=0x3000 pak=0x000000 ds=0x000000 status=80 pak_size=0
01 bd_ptr=0x3014 pak=0x000000 ds=0x000000 status=80 pak_size=0
02 bd_ptr=0x3028 pak=0x000000 ds=0x000000 status=80 pak_size=0
Austin-bottom#
103
