cisco 2505 Hub
I am having trouble connecting to the hub ports on my Cisco 2505, i have tried with straight through cables, twisted, nothing seems to work, below is my curent config let me know if im doing something wrong
Current configuration:
version 11.0
service udp-small-servers
service tcp-small-servers
hostname RouterA
hub ether 0 1
link-test
auto-polarity
hub ether 0 2
link-test
auto-polarity
hub ether 0 3
link-test
auto-polarity
hub ether 0 4
link-test
auto-polarity
hub ether 0 5
link-test
auto-polarity
hub ether 0 6
link-test
auto-polarity
hub ether 0 7
link-test
auto-polarity
hub ether 0 8
link-test
auto-polarity
RouterA#sh ver
IOS (tm) 3000 Software (IGS-IR-L), Version 11.0(8), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Sat 27-Apr-96 01:34 by vprasad
Image text-base: 0x03025184, data-base: 0x00001000
ROM: System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
ROM: 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(8a), RELEASE SOFTWARE (fc1)
RouterA uptime is 17 hours, 54 minutes
System restarted by reload
System image file is "flash:igs-ir-l.110-8", booted via flash
cisco 2505 (68030) processor (revision K) with 6144K/2048K bytes of memory.
Processor board ID 02954648, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Primary Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface.
8 Ethernet/IEEE 802.3 repeater ports.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
Brian Butler
Re: cisco 2505 Hub
Remove the link-test command (ie. disable this feature if a device at the other end of the hub does not implement the link test function) and then try it (may need shut/no shut).
Hope it helps.
Steve
Re: cisco 2505 Hub
No that did not seem to do it.
458
