Cisco 2509 Routing Problem
After switching to new ISP connecteion via Broadband Internet, my dial-up clients connected through 2509 cannot browse the internet. From the router point I can't even ping my ISP DNS server. The last node I can ping from my router is the WAN IP of the Broadband modem installed.
My dial-up clients have no problem before when we are conencted through 64Kpbs domestic leased to the same ISP.
below is my current config;
Current configuration:
version 10.3
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname Music-2509
aaa new-model
aaa authentication login default local
aaa authentication login async local
aaa authentication ppp default local
enable secret 5 $1$KJ.2$xbEgkRc4eqoHkWMlQ7wmP/
enable password 7 0506131C28474F40
username telecom password 7 03105E07030C2E
chat-script cisco-default ABORT ERROR "" "AT Z" OK "ATDT \T" TIMEOUT 30 \c CONNE
CT \c
interface Ethernet0
ip address 203.131.105.110 255.255.255.240
interface Serial0
no ip address
encapsulation ppp
shutdown
interface Serial1
no ip address
encapsulation ppp
bandwidth 64
interface Async1
ip unnumbered Ethernet0
encapsulation ppp
async default ip address 203.131.105.109
async mode interactive
ppp authentication pap
no cdp enable
interface Async2
encapsulation ppp
async default ip address 203.131.105.108
no cdp enable
interface Async3
interface Async4
interface Async5
interface Async6
interface Async7
interface Async8
ip host modem1 2001 203.131.105.110
ip host modem2 2002 203.131.105.110
ip host modem3 2003 203.131.105.110
ip name-server 202.57.96.3
ip name-server 202.57.96.4
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
snmp-server community public RO
line con 0
line 1 8
login authentication async
modem InOut
autoselect ppp
script dialer cisco-default
transport input all
rxspeed 57600
txspeed 57600
flowcontrol hardware
line aux 0
transport input all
line vty 0
exec-timeout 0 30
password 7 141B171F01012325
line vty 1 4
end
Re: Cisco 2509 Routing Problem
To add some details on my first email, my LAN and workstations works fine on this new broadband connection. I basically used Wingate proxy and use private Ip address to all my workstations.
My ISP gave me registered ip 203.131.105.96 /28.
Basically I assigned 203.131.105.110 to Ethernet port (E0) of my router with subnet mask of 255.255.255.240.(shown on my config).
Thanks for any help.
Have your ISP check their routing. You can ping the Broadband modem ( I'm guessing you mean on your end), but nothing else. It sounds like you have a route to the ISP but they don't have a route back.
130
