05-14-2002 02:42 AM - edited 03-01-2019 09:43 PM
I have a 2610 with a 16 port analogue modem module. I use the 2610 to connect some Point of sale devices (POS) to connect to a UNIX host to a specific port.
The problem is that the POS dials and connects to the router and the router line / modem shows that it is connected but then no session or connection is established with the UNIX host.
Suggestions Please
05-14-2002 10:23 AM
Whats your configuration like ? I hope you have some autocommand telnet or connect under the tty lines pointing towards the unix host.
~Zulfi
05-14-2002 01:49 PM
Need to take a look on the config first..When the POS dials in the router, after modem connection you will see the DSR comes up and after that the router will forward that connection thru "autocommand" (configured under the line)..
If the "autocommand
debug modem
debug ip tcp trans
