Cisco 2611 running S26C-12102 - upgrade to FE
I have a customer using 2611's on site running S26C-12102 who want to upgrade the speed of their LAN from 10Mb to 100Mb.
I have the part number of the required Fast Ethernet module (NM-1 FE-Tx) but am unsure if any IOS upgrade will be required to support it. Anyone know?
1 REPLY
Re: Cisco 2611 running S26C-12102 - upgrade to FE
I believe Cisco does not officially "endorse" NM-1fe-tx module on older verion 2600 routers. The 12.1 IOS version does indeed allow this module to work properly on the 2600 series routers. I have a couple 2600 series routers in a lab and have found certain 12.0 release IOS version to work however to be certain use 12.1 or greater.
107
