Cisco 2620 Dial In / Logging Into NT Domain Problem
I have a Cisco 2620 with 8 port async analogue modem card.My remote users dial into this box from home using normal analogue modems over the PSTN.They connect in ok and the dialback calls them back succesfully.They get an IP address from the RAS pool and all connectivity/pings works fine.
The problem is that I have set the Windows Dial Up networking to connect to a NT domain.THIS ALWAYS FAILS THE FIRST TIME BUT BY PRESSING OK (UPON THE NO DOMAIN SERVER COULD BE FOUND ERROR),THE REMOTE CLIENT THEN LOGS IN SUCCESSFULLY THE 2ND TIME. Why does this happen ???
Re: Cisco 2620 Dial In / Logging Into NT Domain Problem
Are you running WINS for Microsoft Network naming resolution? Have you all the settings on the remote computer correctly?
In some cases, it can help to use the LMHOSTS file #PRE entries to locate your PDC or BDC.
Shot in the dark here but...lets say the ip of the pdc is x.x.x.x and the bdc is y.y.y.y...and your lan interface is ethernet0...do this:
config t
int ethernet0
ip helper-address x.x.x.x
ip helper-address y.y.y.y
end
See if that helps.
Josh
Hi josh,
I am also getting same problem, as my clients can obtain ipaddress form DHCP server but as I have set ipnegociated at bri interface, but after obtaining ipaddress form DHCP server the client could not ping the same netwrok form which the client obtain ipaddress, Please if you could look at this.
following is the running configuration.
kiit#sh running-config
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname kiit
enable secret 5 $1$A6Pk$cC6fnLAgwigxkDb.tzBxf/
username furquan password 0 XXXXXXX
ip subnet-zero
ip name-server 194.170.1.6
ip name-server 203.135.0.2
ip dhcp-server 172.16.1.2
isdn switch-type basic-net3
isdn voice-call-failure 0
interface FastEthernet0/0
ip address 202.125.132.41 255.255.255.248
no ip directed-broadcast
ip nat inside
duplex auto
speed auto
interface BRI0/0
ip address negotiated
ip helper-address 172.16.1.2
encapsulation ppp
peer default ip address dhcp
ppp pap sent-username kiit07@isdn.cyber.net.pk password 7 060B0E28407102100C03
ppp multilink
interface Serial0/0
ip address 202.163.110.22 255.255.255.252
encapsulation ppp
shutdown
interface FastEthernet0/1
ip address 172.16.254.252 255.255.0.0
ip nat inside
duplex auto
speed auto
interface Serial0/1
ip address 202.125.131.22 255.255.255.252
ip nat outside
interface Dialer0
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1
ip route 172.16.0.0 255.255.0.0 FastEthernet0/1
no ip http server
snmp-server engineID local 0000000902000004278EE7A0
snmp-server community public RO
snmp-server community snmp view v1default RO
snmp-server enable traps snmp
snmp-server host 202.125.132.43 snmp
line con 0
password rose
transport input none
line aux 0
line vty 0 1
password XXXXXXXXXXXXXXXX
login
line vty 2 4
login
no scheduler allocate
end
kiit#
Make your BRI interface unnnumbered to your fastE and see if that fixes it. I doubt your peer, who is asking you for an address, is going to give you one.
Josh
136
