Cisco 2620 Serial 1 Connect to Serial 1 ?
I try to connect connect router serial 1 to another router serial 1 on Cisco 2620 routers.
Is it possible to make both interface up ? Do i need to set clockrate ?
1 ACCEPTED SOLUTION
Re: Cisco 2620 Serial 1 Connect to Serial 1 ?
I guess you have used a v.35 back to back serial cable (smart serial connectors for 2620, in case u r using wic-2t) to connect between the serial ports. On the DCE end of the cable, on the router serial port, you need to configure clock (since this is a back to back connection)
int s0/1
clock rate 56000
Now to find out which end is dce and which end is dte, you can either look at the cable (most cables should have it marked "DCE")
Or else give a "show controllers s0/1" and you should be checking on the output for a line which says DCE or DTE. If its DCE and no clock is configured, then it should show up as "DCE, no clock configured". If there is no cable attached, it should show up as "DCE, No cable". When configured with a clock, it should show up as "DCE, clockrate ".
Hope that helps.
1 REPLY
int s0/1
clock rate 56000
Hope that helps.
303
