Cisco 2621 reload problems
When I reload a cisco 2621 using 12.2(7) software it goes through the start up intialisation and then comes back with a %Software-forced reload message and then hangs.
Any ideas ?
  • Other Network Infrastructure Subjects
Re: Cisco 2621 reload problems
Hopefully this might help!
http://www.cisco.com/warp/public/122/crashes_swforced_troubleshoot.html
Can u paste what messages are coming on the screen?
Yeh I've seen that link but it referes to crashes that haven't been induced by a reload.
Here's what happens;
reload
Proceed with reload? [confirm]
*Mar 1 00:20:26.508 UTC: %SYS-5-RELOAD: Reload requested
System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2001 by cisco Systems, Inc.
C2600 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x97a858
Self decompressing the image : ######################################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000A2 0X0010A400 C2600 Dual Fast Ethernet
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X0040EFB0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 5Mb.
Using 7 percent iomem. [5Mb/64Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 15-Jan-02 23:58 by pwade
Image text-base: 0x80008088, data-base: 0x81070674
It hang's from here
Silver
try to break in to rommon change the config register to x2142 then reset . See if the box boots up ignoring the settings in NVRAM
I can't break into the box once it has hung, but when I power off/on it loads OK.
I've just tried setting the confreg to 0x2142 in global config mode and issued a reload, but again it's hung.
Silver
how did you change the config register in global config if the box hangs ? Do you have 2 verisions of code on the box and are able to load one code but not the other ?
Silver
what code is loaded ?
can you paste in your boot statements and a sh flash
You need to break in to the box when th # signs are streaming across the screeen
HI
You should set your configure registry to 0x2102 that solve your problem and then reset your router .
NIX TECH.
MOhsen.
137
