Cisco 2621 Router Problems
I attend a Cisco Academy. In my lab I am required to make six router be able to communicate via Serial ports. Even though my configuration appears to be working, I cannot ping other routers from the CLI. Is there a command or protocol that I am missing. Here is the CLI:
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname LAB-A
enable password cisco
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
interface FastEthernet 0/0
no shutdown
description connected to Cisco1538
ip address 192.5.5.1 255.255.255.0
keepalive 10
interface FastEthernet 0/1
no shutdown
description connected to Cisco1548
ip address x.x.x.1 255.255.255.0
keepalive 10
interface Serial 0/0
no shutdown
description connected to LAB-B
encapsulation ppp
interface Serial 0/1
no description
no ip address
shutdown
router rip
version 2
network 192.5.5.0
network 205.7.5.0
network 201.100.11.0
no auto-summary
ip classless
no ip http server
snmp-server community public RO
no snmp-server location
no snmp-server contact
line console 0
exec-timeout 0 0
password cisco
login
line vty 0 4
password cisco
login
end
1 REPLY
Re: Cisco 2621 Router Problems
I would first start with one router and see if you can ping the adjacent router (connected via serial interface). If this fails go ahead look at status of the serial interface. Since this is a lab setup i would assume, back to back serial cables on your routers. This requires that you put a clock rate command on the DCE end of the cables on the routers.
int s0/0
clock rate 56000 would do.
The line protocol of the serial interface would be down, if the clock rate command is not given.
You can find which end of router is DCE / DTE by using the command, "show controllers s0/0"
401
