Community Member
cisco 2621XM and tcp , RTP header compression
hi
Im getting very slow web access when I have Tcp and RTP header compression on the cisco2621XM router running 12.2(12a). It takes few minutes to load the pages and as soon I remove the compression the web page loads in 2 sec. Strangly it sonly happening on 2621Xm router and if I test same confg with other 2600 it works fine. Need to have compression ON as it will be passing soem voice traffic. Has anybody seen this problem on2621xm?
Building configuration...
Current configuration : 3828 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Lab_test
enable secret 5 <removed>
username labtest password 0 <removed>
ip subnet-zero
call rsvp-sync
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description "Unsecured Network"
encapsulation isl 2
ip address 172.24.16.1 255.255.255.0
ip access-group 100 in
no ip redirects
interface FastEthernet0/0.2
description "Secured Network"
encapsulation isl 3
ip address 172.24.17.1 255.255.255.0
no ip redirects
interface FastEthernet0/0.3
description "Onward Link 1 VLAN"
encapsulation isl 10
ip address 172.24.18.1 255.255.255.248
no ip redirects
interface FastEthernet0/0.4
description "Onward Link 2 VLAN"
encapsulation isl 20
ip address 172.24.18.9 255.255.255.248
no ip redirects
interface FastEthernet0/0.5
description "Onward Link 3 VLAN"
encapsulation isl 30
ip address 172.24.18.17 255.255.255.248
no ip redirects
interface FastEthernet0/0.6
description "Onward Link 4 VLAN"
encapsulation isl 40
ip address 172.24.18.25 255.255.255.248
ip access-group 101 in
no ip redirects
interface Serial0/0
description "WAN Link to Core 2 (Cisco 3662)"
bandwidth 2048
ip address 172.20.252.46 255.255.255.252
encapsulation ppp
ip tcp header-compression iphc-format
no ip mroute-cache
no fair-queue
clockrate 2000000
ip rtp header-compression iphc-format
ip rtp priority 16384 16383 270
interface FastEthernet0/1
no ip address
shutdown
speed 100
full-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 172.20.252.45
no ip http server
access-list 100 permit ip any host 131.142.232.15
access-list 100 permit ip any host 131.142.170.61
access-list 100 permit ip any host 131.142.170.63
access-list 100 permit ip any 172.20.0.0 0.0.255.255
access-list 100 permit ip any host 131.142.173.5
access-list 100 permit ip any host 131.142.170.59
access-list 100 permit ip any host 131.142.170.62
access-list 100 permit ip any host 131.142.170.64
access-list 100 permit ip any host 192.168.2.32
access-list 100 permit ip any host 172.20.36.15
access-list 100 permit ip any host 172.20.36.18
access-list 100 permit ip any host 131.142.170.67
access-list 100 permit ip any host 131.142.170.72
access-list 100 permit ip any host 131.142.170.73
access-list 100 permit ip any host 131.142.180.25
access-list 100 permit ip any host 131.142.230.50
access-list 100 deny ip any any
access-list 101 permit ip host 172.24.18.26 host 131.142.172.46
access-list 101 permit ip host 172.24.18.27 host 131.142.172.46
access-list 101 permit ip host 172.24.18.26 host 131.142.170.59
access-list 101 permit ip host 172.24.18.27 host 131.142.170.59
access-list 101 permit ip host 172.24.18.26 host 131.142.230.50
access-list 101 permit ip host 172.24.18.27 host 131.142.230.50
access-list 101 permit ip host 172.24.18.26 host 131.142.170.63
access-list 101 permit ip host 172.24.18.27 host 131.142.170.63
access-list 101 permit ip host 172.24.18.26 host 131.142.170.64
access-list 101 permit ip host 172.24.18.27 host 131.142.170.64
access-list 101 permit ip host 172.24.18.26 host 131.142.170.30
access-list 101 permit ip host 172.24.18.27 host 131.142.170.30
access-list 101 deny ip any any
snmp-server community <removed> RW
snmp-server location xxxx
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
dial-peer cor custom
line con 0
password <removed>
login local
line aux 0
line vty 0 4
password <removed>
login
end
1 ACCEPTED SOLUTION
Bronze
Re: cisco 2621XM and tcp , RTP header compression
As far as I know, RTP and TCP header compression is supported on the 2600 but not on the 2621XM. The feature navigator shows that this feature is available on the 2651XM.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t7/rtpfast.htm#wp7704
Bronze
Community Member
Yes we found out that its not supported . thanks for yr reply
91
