Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco 2948G Power supply failures
This is the command from sh log
Does anyone have any idea why the power supply failures are under #2 when there is no #2? Sure would like any help you can give me.
CSB-1> (enable) sh log
Network Management Processor (ACTIVE NMP) Log:
Reset count: 77
Re-boot History: Feb 01 2002 04:07:53 0, Feb 01 2002 03:20:39 0
Feb 01 2002 03:16:14 0, Jan 30 2002 03:13:50 0
Jan 29 2002 12:54:15 0, Jan 29 2002 12:50:41 0
Jan 29 2002 12:42:15 0, Jan 25 2002 12:36:55 0
Jan 24 2002 05:03:45 0, Jan 24 2002 04:17:43 0
Bootrom Checksum Failures: 0 UART Failures: 0
Flash Checksum Failures: 0 Flash Program Failures: 0
Power Supply 1 Failures: 0 Power Supply 2 Failures: 59
DRAM Failures: 0
Exceptions: 0
Last software reset by user: 3/8/2000,11:10:12
MCP Exceptions/Hang: 0
Heap Memory Log:
Corrupted Block = none
NVRAM log:
Re: Cisco 2948G Power supply failures
That sure doesn't make sense. The only way that this chassis can have 2 PSU's is if you had a redundant power supply RPS connected. It would be interesting to see what you switch says when you input the command "show sys" under the PS2-Status?
If there definately isn't a RPS connected to the switch then I would get it swapped out if you have a maintenance contract, as there is definately a fault with it.
You probably had a power supply 2 in the switch earlier. Please do clear log on the switch and this will clear all the entries in the log.
CAT2948G does not have a built in redundant PS. Unless you had an external RPS, I suspect it to be a cosmetic bug. I'll do some scrubbing to see if I can find one
Bronze
can you please paste the output of show env all, show system , sh mod , sh ver from the switch and then do clear log to see if that are incrementing..
204
