Cisco 2950 connection to BBSM 5.3
Hi All
I Configure a 2950 switch to enable guest to browse through BBSM 5.3
The guest can browse when connect to the switch but i cannot see the switch active in the BBSM Server.
How can make the switch active?
1 REPLY
Re: Cisco 2950 connection to BBSM 5.3
what type of configuration do you have for the BBSM is it a layer 2 type of config or is it a layer 3 type of config? verify that the snmp string is correct as well, you can go into the system summary section and look in the network devices section, it will tell you there if the snmp connection has worked or not.
219
