Cisco 3550-48-EMI VLAN Routing Issue II
Here's our network diagram.
INTERNET
Cisco 1720
Nokia IP120 Firewall
| (e0 : 10.140.70.254/24) VLAN 70
|(fa0/48: 10.140.70.253/24)
| Cisco 3550 |------(10.140.90.254/24)
+-----------------------+ VLAN 90
| (10.140.100.254/100)
| VLAN 100
I have a host on each VLANs and they can communicate each other.
But...only except for host within VLAN 70 could hit the internet.
Any hosts in VLAN 100 and 90 are not able to hit 10.140.70.254.
Could you please let me know how to resolve this problem?
Here's my configuration.
Using 4843 out of 393216 bytes
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname NPBC0001
enable secret xxxxx
enable password xxxxx
clock timezone GMT -8
clock summer-time GMT recurring
ip subnet-zero
ip routing
cluster enable Macsteel 0
interface FastEthernet0/1
description Primary Link for NPBS2S01
switchport access vlan 90
switchport mode access
no ip address
interface FastEthernet0/2
description Secondary Link for NPBS2S01
no ip address
interface FastEthernet0/3
description RIB Link for NPBS2S01
no ip address
interface FastEthernet0/4
description Primary Link for NPBS2S02
no ip address
interface FastEthernet0/47
switchport access vlan 70
no ip address
interface FastEthernet0/48
no ip address
duplex full
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 10.140.100.18 255.255.255.0
no ip route-cache cef
interface Vlan70
ip address 10.140.70.253 255.255.255.0
interface Vlan90
ip address 10.140.90.254 255.255.255.0
interface Vlan100
ip address 10.140.100.254 255.255.255.0
no ip address
interface Vlan110
ip address 10.140.110.254 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.140.70.254
ip http server
ip access-list extended CMP-NAT-ACL
dynamic Cluster-HSRP deny ip any any
dynamic Cluster-NAT permit ip any any
line con 0
line vty 0 4
password xxxxx
login
line vty 5 15
password xxxxx
login
end
Thank you very much for your help in advance.
Thanks.
Bronze
Re: Cisco 3550-48-EMI VLAN Routing Issue II
For me it looks like you forgot to route the
networks from VLAN 90 and 100 and also the others on
the firewall.
You should have routing entries on the firewall like
10.140.110.0/24 pointing to 10.140.70.253
10.140.100.0/24 pointing to 10.140.70.253
10.140.90.0/24 pointing to 10.140.70.253
The config of the 3550 looks o.k.
Hope that helps
Roger
Thanks Roger,
Hmm..Why didn't I thought of the firewall??
You're my lifesaver! As soon as I add static routes to firewall, it worked like a magic!
Thanks again.
Bronze
I'm glad that i could help you!
Roger
233
