Cisco 3550-48-EMI VLAN routing issue...
Hi all,
Here's out network layout;
Nokia IP120 Firewall
| (10.140.100.254)
|(10.140.100.253) VLAN 100
| 3550-48-EMI|--------VLAN90 (10.140.90.254)--------
|(10.140.110.254) VLAN 110
I have two workstations at each subnet(VLAN110 & 100) has default gateway of their VLAN IP address. How can I make each VLANs routable? I tried to ping from the workstation at VLAN 110 to 90(or vice versa) but it's not working for some reasons. Could you please review its configuration and correct the issues? Thank you very much for your help in advance.
- Jon
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname NPBC0001
enable secret xxxxx
enable password xxxx
ip subnet-zero
interface FastEthernet0/1
no switchport
no ip address
interface FastEthernet0/2
switchport access vlan 90
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
switchport access vlan 110
no ip address
interface FastEthernet0/5
switchport access vlan 100
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan100
ip address 10.140.100.253 255.255.255.0
interface Vlan90
ip address 10.140.90.254 255.255.255.0
interface Vlan110
ip address 10.140.110.254 255.255.255.0
ip default-gateway 10.140.100.254
ip classless
ip http server
password xxx
login
line vty 5 15
password xxxx
login
end
Re: Cisco 3550-48-EMI VLAN routing issue...
Hi Jon,
Have you configured your V-lan´s in your V-lan database yet? (show vlan)
If not, you can do so with the "vlan database" command in enable mode att the promt in your Catalyst 3550.
Kalle
is there "ip routing" command present in the config?
Milan
Bronze
Just to add, are you able to ping between workstations on VLAN 90? I was just thinking why don't you have the 'switchport mode access' command under the FastEthernet interfaces configured as Layer 2 interfaces. I believe you need this command since you have configured static-access VLANs.
First of all, thanks for your solution. Just simple adding 'ip routing' command and 'switchport mode access' to interface simply resolved this issues.
I can ping to any hosts from different VLANs but it seems that any hosts that resides in VLAN, cannot hit the internet at all.
Do I need to add static route(to the internet) to switch configuration?
Please let me know.
Thanks.
- Jon
Gold
Jon,
Yes, once you turned on "ip routing" the "ip default-gateway" command ceased to be useful. (The "ip default-gateway" command is for routers, switches, etc., that have IP routing turned off and are just acting as IP hosts.)
Go into config, add "ip route 0.0.0.0 0.0.0.0 10.140.100.254", save your configuration, and you're on your way. See you on the Internet...
Hope this helps.
Thanks guys.
All the issues has been resolved.
I really appreciated your help.
- Jon
145
