Cisco 3560 High CPU in Layer 3 Mode
mmendis
Dear All,
Recently I have configured a Cisco 3560 Switch as Layer 3 ( By enabling ipservices evaluation licene ). And it was worked fine untill I have connected few uplinks which carries 5M of traffic. Now the Switch CPU usage is very high ( 68% ).
#show proc cpu sorted
CPU utilization for five seconds: 69%/18%; one minute: 67%; five minutes: 67%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
222   222384302   190788354       1165 36.00% 37.53% 37.58%   0 IP Input
  11     2375852       27182      87405  4.32%  0.57%  0.41%   0 Licensing Auto U
  85    10770348     1970370       5466  1.27%  1.54%  1.61%   0 RedEarth Tx Mana
  84     5106559     2697243       1893  1.27%  0.80%  0.74%   0 RedEarth I2C dri
174     6004519    12581166        477  0.79%  0.90%  0.95%   0 Hulc LED Process
382      382375        9238      41391  0.63%  0.08%  0.05%   0 BGP Scanner
177     2663114      368240       7232  0.31%  0.40%  0.42%   0 HL3U bkgrd proce
412         191         119       1605  0.31%  0.15%  0.03%   2 Virtual Exec
  13     1309028     1410026        928  0.31%  0.19%  0.20%   0 ARP Input
  86      392760     1348624        291  0.31%  0.07%  0.05%   0 RedEarth Rx Mana
109      268974    14346086         18  0.15%  0.04%  0.00%   0 HLFM address ret
  56      860528      506222       1699  0.15%  0.17%  0.15%   0 Per-Second Jobs
107      373092    14345964         26  0.15%  0.07%  0.05%   0 HLFM address lea
189      269440      201877       1334  0.15%  0.06%  0.05%   0 HRPC qos request
358      420345    15699794         26  0.15%  0.03%  0.04%   0 MMON MENG
188     1047234      100949      10373  0.15%  0.15%  0.15%   0 HQM Stack Proces
  17           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  18           8           7       1142  0.00%  0.00%  0.00%   0 Entity MIB API
  19           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  20        3504      100977         34  0.00%  0.00%  0.00%   0 IPC Event Notifi
  21        7955      490784         16  0.00%  0.00%  0.00%   0 IPC Mcast Pendin
  22          68        8436          8  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  24           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  16           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  26        7981      490784         16  0.00%  0.00%  0.00%   0 IPC Deferred Por
  27           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  28        9559      155634         61  0.00%  0.00%  0.00%   0 IPC Seat Manager
  29         401       28909         13  0.00%  0.00%  0.00%   0 IPC Check Queue
  30           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  31           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  32         743       50618         14  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  33        1556      101063         15  0.00%  0.00%  0.00%   0 IPC Loadometer
  15           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  25        8608      490779         17  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  34          50           4      12500  0.00%  0.00%  0.00%   0 PrstVbl
  37       10831      506089         21  0.00%  0.00%  0.00%   0 GraphIt
  38        2360         196      12040  0.00%  0.00%  0.00%   0 crypto sw pk pro
  39           0           2          0  0.00%  0.00%  0.00%   0 SMART
  40           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  41           0           1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  42       15469      501603         30  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  43           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  44       72599      755144         96  0.00%  0.00%  0.00%   0 Net Background
Can some one explain this issue.
Best Regards !!!
2 Accepted Solutions
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Use Universal image; your license should allow that image to provide IPService features.
Oh, and if CPU is high for L3, you might not be using the optimal SDM template.
You never mentioned that you are using 3560X, hence I didn't know.
As what Joseph mentioned, get the "universal" IOS.
Don't forget to rate our useful posts.  Thanks.
11 Replies 11
Leo Laohoo
Would be nice if you can post the output to the command "sh version".
Please refer the below.
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 15.0(2)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 05-Feb-13 12:04 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
NMC-0.77-3560 uptime is 5 days, 21 hours, 36 minutes
System restarted at 13:06:09 LKR Thu Aug 15 2013
System image file is "flash:c3560e-universalk9-mz.150-2.se2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipservices
License Type: Evaluation
Next reload license Level: ipservices
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1622R1X9
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : D8:67:D9:CA:0D:80
Motherboard serial number       : FDO16220EZK
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3560X-24T-L
Version ID                      : V02
CLEI Code Number                : COMJU00ARB
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       15.0(2)SE2            C3560E-UNIVERSALK9-M
Configuration register is 0xF
Version 15.0(2)SE2
Here's the dig ... If you are a 3560- or 3750-series switch and running 802.1X and/or PoE or just Layer 3, it's best to avoid this version.  Go to 15.0(2)SE4 and observe.
Thanks Leo for helping ... Is it ok if I use 122-55.SE4 ???
Use 12.2(55)SE8 instead.
Hello Leo,
I have tried with c3560-ipservicesk9-mz.122-55.SE8 but it saying not compltibale with the Hardware.
My Switch model is WS-C3560X-24T-L , and I couldn't find a ipservices image for this model ( accordig to Cisco IOS locator) .
Please help
Disclaimer
Posting
Thanks Joseph ... I think it worked. SDM Template was set to default I have changed it as well as the IOS.
Leo , thanks mate really helped
Glad to be of some assistance.
