Webcast-Catalyst9k
Cisco 3560 Power Problem
The power on my store last weekend went down. My 2600 series Router whem the power comes up, its ok, but my 3560 SW, nothing. the sw only start if i take off the power supply cable and put it again.
Any suggestion ????
Re: Cisco 3560 Power Problem
Hi Miguel,
Some of the 3560 switches use a power supply that latches off when there is a short duration dip in voltage. This is used to protect the switch from damage caused by voltage surges.
Please reference CSCeh20636
Greg Macaulay
OK Thanks.
Cisco have a workaround for this subject. Supose i have a store at 200Km from my office. The solution is to drive there and power on the SW.
Do you have the Switch properly grounded? In many cases Static Electricity causes Devices to hang. The Best solution is to ensure that switch is properly grounded.
Hope this works.
Wilson Samuel
224
