06-12-2016 03:29 AM - edited 03-03-2019 08:15 AM
HI there guys.
have a 3560 that shows no display on screen, but lights flash after booting up and finish with SYS light static and still no display if I console on to it. Any help appreciated. Thanks Chris
06-13-2016 02:14 AM
Hi, maybe your console speed is different than default.
Try another supported speeds.
Or also console port can be "dead". Hard to say.
06-13-2016 12:39 PM
Thanks for your help.
console is set to 9600 and works will all my other equipment..I have spoken to other people all with similar devices producing the same result and of the same make and model, so possibly a fault with this model. Thanks for your help. Chris
