Webcast-Catalyst9k
Cisco 3640 10Mbps to Catalyst 2900xl switch errors
Dear All
I have a few 3640 routers in my network with 10Mbps Ethernet connecting to 2900XL switches. I get on all of them lots of errors.
I was told previously to set the ethernet port to full duplex and set the switch to full/10 . I have tried and am still getting errors.Ethernet0/0 is up, line protocol is up
Hardware is AmdP2, address is 0050.7368.31c1 (bia 0050.7368.31c1)
Internet address is x.x.x.x/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 3/255, rxload 18/255
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 6d02h
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 1/75, 0 drops
5 minute input rate 725000 bits/sec, 170 packets/sec
5 minute output rate 142000 bits/sec, 151 packets/sec
55616586 packets input, 178831776 bytes, 12 no buffer
Received 591242 broadcasts, 0 runts, 0 giants, 0 throttles
17252 input errors, 0 CRC, 0 frame, 0 overrun, 17252 ignored
52738256 packets output, 1834410437 bytes, 0 underruns(751133/1791328/0)
0 output errors, 2542461 collisions, 0 interface resets
0 babbles, 0 late collision, 1798079 deferred
0 lost carrier, 0 no carrier
Can some one send me a config example of a router 10Mbps ethernet port to a Switch 2900xl that is running with no errors.
Re: Cisco 3640 10Mbps to Catalyst 2900xl switch errors
Full Duplex is not supported on the ethernet interface in your router.
I have tested this with an identical adapter (NM-1E-2W) on my own network, to be 100% certain. The keyword duplex is missing from the interface config-list. Therefore I assume that it is only capable of running in half-duplex-mode and i.e. there is a duplex-mismatch in your network.
I am using IOS 12.0(24) GD on this box.
You probably have configured full duplex only on the 2900-switch?
So the obvious way to improve your error count is to configure your corresponding switch port back to half-duplex.
VIP Purple
not sure what your 3640 config looks like, but do you have the command ' media-type 10BaseT' in your Ethernet interface config of your 3640 ?
I have a 1601 connected to a 2900XL, no probems with the following config:
1601
interface Ethernet0
ip address x.x.x.x
2900
interface FastEthernet0/1
switchport access vlan 10
spanning-tree portfast
So that means no additional config from the default, except for the spanning tree command on the switch.
Georg Pauwen
Do a sh int on your cat2900:
ps02>sh int fa0/21
FastEthernet0/21 is up, line protocol is up
Hardware is Fast Ethernet, address is 0001.63b8.7895 (bia 0001.63b8.7895)
Description: c3640
Keepalive not set
Half-duplex, 10Mb/s, 100BaseTX/FX << Link set to 10Mb, half duplex.
Last input 00:00:35, output 00:00:00, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
43162742 packets input, 4006741198 bytes
Received 22598515 broadcasts, 20799 runts, 0 giants, 0 throttles
20799 input errors, 0 CRC, 0 frame, 0 overrun, 169 ignored
0 watchdog, 22060195 multicast
86790072 packets output, 2395303557 bytes, 0 underruns
2 output errors, 13356 collisions, 3 interface resets
0 babbles, 0 late collision, 42530 deferred
ps02>
The text: 100BaseTX/FX just means that the interface is 100Mb capable.
You will see this text on every interface.
I have the speed set to auto I'll try to change it to 10Mbps on the switch
As you can see it's mainly collisions, you are getting a few errors on your port.
FastEthernet0/24 is up, line protocol is up
Hardware is Fast Ethernet, address is 0005.9bd2.1658 (bia 0005.9bd2.1658)
Description:
reliability 251/255, txload 19/255, rxload 4/255
Keepalive not set
Half-duplex, Auto Speed (10), 100BaseTX/FX
Last input 00:00:58, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w6d
5 minute input rate 190000 bits/sec, 245 packets/sec
5 minute output rate 758000 bits/sec, 273 packets/sec
125440975 packets input, 3364025772 bytes
Received 715868 broadcasts, 5462813 runts, 0 giants, 0 throttles
5462813 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 715462 multicast
134930061 packets output, 133755871 bytes, 0 underruns
0 output errors, 3526903 collisions, 0 interface resets
0 babbles, 0 late collision, 3391182 deferred
Silver
After you changes the duplex setting to full did you reset the port ? You need to bounce the port for the change to take effect
This is my 2900-XL:
interface FastEthernet0/21
description c3640
duplex half
speed 10
Cheers
Ethernet interfaces in Cisco routers work fine with 10 Mbps HALF DUPLEX, but it is normal to have a lot of errors when it is configured to full duplex. Change to HALF DUPLEX both interfaces (switch and router) and errors will dissapear.
regards.
Silver
You should be able to run this at 10 Mb full duplex with no problem . He have many boxes with the same ehternet controller that is running full duplex.
Silver
all of your errors are ignores , ignores are when your interface is overloaded with traffic and there are no free buffers to buffer the packet.
see this URL re ignores.
http://googleweb-1.cisco.com/search?q=cache:http://cco-rtp-1.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a0080094aef.shtml+ignores&ie=UTF-8&site=CDC&output=xml_no_dtd&client=CDC&proxystylesheet=CDC&oe=UTF-8
again you should have no issues going full duplex
Do you have the IOS that supports Full duplex on the 3640 running? I know this is only supported from 12.1 or higher so anything below will not do Full duplex. When looking at your sh int output I see MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, to me that means your IOS does NOT have the duplex support. Collisions are impossible on a full duplex connection!! Duplex mismatch is one of the biggest problems in networking today and causes big delays for the half duplex side checks for traffic/collisions and the full duplex side does not. So my advice is to use half duplex as long as your not sure that you have the support for Full duplex.
Regards, Maarten Sjouw.
Silver
I am running code in the 12.0 mainline that does support Full duplex. It is not the it is the Ethernet controller that dictates .
Well I found this document that discusses the nm2/1e2w part:
http://www.cisco.com/warp/public/107/nm-e2w.shtml
But still you should never see collisions on a full duplex port...
This is a nice document!
Although you could easily misunderstand that some modules are supported in the 2600 & 3600 series.
The URL: http://www.cisco.com/warp/public/779/smbiz/service/pubmatrix/mod/mod227_xref.htm
states correctly what is supported on a 2600. I knew it was there somewhere but I had to search a long time. Not everything has improved after the last overhaul of the Cisco-site but OK. I have the following remarks:
NM-1E1R2W and NW-1E2W are NOT supported. Reading the document you found, one is led to believe that these modules are supported. They are defintely not, I have tested it.
Checking the new features of rel 12.0(4)T gives no clues about the implementation of support for full duplex!?
So what about the quality of this document? (not your fault of course)
You might be right that it is a new feature and it is included with 12.1. Currently we don't have any 3600 series with an ethernet module running under this release. We are using 12.0(24) GD on all these routers and it would really wonder me if Cisco has not built this feature in 12.0 mainline.
I checked several boxes and are all doing half duplex and not capable of more. Next year we will probably upgrade all 3600s to 12.1 and I will keep this in mind.
Silver
Again
I have boxes 2600 & 3600 that are running 12.0 mainline that are running full duplex . Just add the full-duplex command under the interface . You also must reset the interface.
And you are 100% certain that these are not Fast Ethernet interfaces?
For Fast Ethernet interfaces this command is available and working.
On modules with the AmdP2-based ethernetcontrollers like NM-1E, NM-1E1R2W, NM-1E2W this option is NOT available under interface configuration.
Neither is the command media-type xx. The latter has also been referred to in this discussion but is only relevant for the 4000 series.
Our current release is 12.0(24) IP/IPX/AT/DEC plus. (ds-mz) We also use 12.1(17) but (unfortunately) not on routers with this type of controllers.
In the coming week I might be able to test this in the lab. I'll keep everyone posted.
Silver
Yes I am certain they are 10 mb cards I am running 12.0 T train
ps the media type command is 4000 series specific
To me, when one writes: 12.0 mainline, I assume one means the -GD- releases. So lets say I misunderstood. When you are running on a T-version this confirms the posting of mr Sjouw. This means that it is very likely that it also works in 12.1 and it definitely is IOS-related.
It may in turn help you to know that it is NOT implemented in 12.0(x) GD
Cheers
302
