Cisco 3640 and ISDN Callback doesn't work
I' m trying to configure a Cisco 3640 with 4 BRI and 12 Digital Mica Modem.
Callback with analog modem is working fine.
I' m having troubles with ISDN callback.
On ISDN q.931 debug cisco router, when it starts to call, receive the following message:
02:01:27: ISDN BR2/3: RX <- DISCONNECT pd = 8 callref = 0x97
02:01:27: Cause i = 0x80D8 - Incompatible destination
I'm using ios vers. c3640-i-mz.122-13b.bin but I also tried other IOS versions.
As ISDN TA on client I used Digicom Palladio ISDN-USB and Zyxel
This is the cisco configuration:
Router#sh run
Building configuration...
Current configuration : 2030 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
aaa new-model
aaa authentication ppp default local
aaa authorization network default local
enable secret 5 $1$2R/p$CvBEcaGMnsXTaTt9ZA3MR.
username test callback-dialstring "" password 0 test
ip subnet-zero
ip domain-list bocchiotti.it
no ip domain-lookup
isdn switch-type basic-net3
chat-script callback ABORT ERROR ABORT BUSY "" "ATDT\T" TIMEOUT 120 "CONNECT
interface FastEthernet0/0
ip address 128.1.5.3 255.255.0.0
no keepalive
duplex auto
speed auto
interface BRI2/0
no ip address
encapsulation ppp
shutdown
isdn incoming-voice modem
ppp authentication chap pap
interface BRI2/1
no ip address
encapsulation ppp
shutdown
ppp authentication pap chap
interface BRI2/2
no ip address
encapsulation ppp
shutdown
interface BRI2/3
no ip address
encapsulation ppp
dialer pool-member 2
interface Group-Async1
physical-layer async
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer callback-secure
dialer-group 1
async mode interactive
peer default ip address pool default
ppp callback accept
interface Dialer1
encapsulation ppp
dialer pool 2
dialer-group 1
ppp callback accept
ip local pool default 192.168.200.100 192.168.200.130
ip classless
ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
no cdp run
line con 0
line 33 44
flush-at-activation
line aux 0
line vty 0 4
password cisco
end
And ISDN q.931 debug:
outer#deb isdn q931
ISDN Q931 packets debugging is on
Router#
02:01:01: ISDN BR2/3: RX <- SETUP pd = 8 callref = 0x3D
02:01:01: Bearer Capability i = 0x8890
02:01:01: Channel ID i = 0x89
02:01:01: Calling Party Number i = 0x21, 0x83, '103071401', Plan:ISDN, Type:
02:01:01: Called Party Number i = 0xA1, '103072700', Plan:ISDN, Type:Nationa
02:01:01: Sending Complete
02:01:01: ISDN BR2/3: Event: Received a DATA call from 103071401 on B1 at 64 Kb/s
02:01:01: ISDN BR2/3: Event: Accepting the call id 0x3E
02:01:01: %DIALER-6-BIND: Interface BR2/3:1 bound to profile Di1
02:01:01: %LINK-3-UPDOWN: Interface BRI2/3:1, changed state to up
02:01:03: %ISDN-6-LAYER2UP: Layer 2 for Interface BR2/3, TEI 90 changed to up
02:01:03: ISDN BR2/3: TX -> CALL_PROC pd = 8 callref = 0xBD
02:01:03: Channel ID i = 0x89
02:01:03: ISDN BR2/3: TX -> CONNECT pd = 8 callref = 0xBD
02:01:03: ISDN BR2/3: RX <- CONNECT_ACK pd = 8 callref = 0x3D
02:01:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI2/3:1, changed state to
02:01:07: %ISDN-6-CONNECT: Interface BRI2/3:1 is now connected to 103071401 sala
02:01:08: ISDN BR2/3: RX <- DISCONNECT pd = 8 callref = 0x3D
02:01:08: Cause i = 0x8090 - Normal call clearing
02:01:08: %ISDN-6-DISCONNECT: Interface BRI2/3:1 disconnected from 103071401 sala,
02:01:08: %LINK-3-UPDOWN: Interface BRI2/3:1, changed state to down
02:01:08: %DIALER-6-UNBIND: Interface BR2/3:1 unbound from profile Di1
02:01:08: ISDN BR2/3: TX -> RELEASE pd = 8 callref = 0xBD
02:01:08: ISDN BR2/3: RX <- RELEASE_COMP pd = 8 callref = 0x3D
02:01:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI2/3:1, changed state to
02:01:21: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR2/3, TEI 90 changed to down
02:01:23: %ISDN-6-LAYER2UP: Layer 2 for Interface BR2/3, TEI 90 changed to up
02:01:23: ISDN BR2/3: TX -> SETUP pd = 8 callref = 0x17
02:01:23: Bearer Capability i = 0x8890
02:01:23: Channel ID i = 0x83
02:01:23: Called Party Number i = 0x80, '0103071401', Plan:Unknown, Type:Unk
02:01:23: ISDN BR2/3: RX <- CALL_PROC pd = 8 callref = 0x97
02:01:23: Channel ID i = 0x8A
02:01:27: ISDN BR2/3: TX -> RELEASE pd = 8 callref = 0x17
02:01:27: ISDN BR2/3: RX <- RELEASE_COMP pd = 8 callref = 0x97
02:01:41: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR2/3, TEI 90 changed to down
Thanks in advance
Marco Parmigiani
Digipoint srl
Genova- Italy
Silver
Re: Cisco 3640 and ISDN Callback doesn't work
During the call IN we see the following:
Calling Party Number '103071401', Plan:ISDN, Type:
Called Party Number '103072700', Plan:ISDN, Type:National
During CALLBACK, the number dialed is:
Called Party Number '0103071401', Plan:Unknown, Type:Unk
We see a Zero before the called number....not sure why. As a simple test try making an ISDN call from this 3640 & see if it connects with which number,
3640#isdn call interface bri2/3 0103071401
AND
3640#isdn call interface bri2/3 103071401
deb isdn q931 / deb ppp nego / deb dialer / deb callback will be helpful.
For ISDN q931 cause code:
http://www.cisco.com/warp/public/129/isdn_disc_code.html
Thanks, Mak.
We have tested dialer string and it worked fine. The phone number we used was 0103071401.
We have tried a wrong phone number and we receive an ISDN message that the phone is bad.
We have tried a lot of debug (but not deb callback) .
When the router callback the pc no ppp negotiation start because the call stops at ISDN level.
Thanks for help
Marco
You are using Basic-Net3 as your ISDN type, are you sure this is correct for your country? (don't know where you are located)
Something else I see that will resolve a lot of headaches later:
- Change your dialer callback to PERMIT otherwise you can have problems cancelling callback.
- Use rotary groups instead of Dialer Pools as the pools cause problems with multiple isdn users connecting. Remove the dialer pool statements and add into the BRI's dialer rotary-group 1 This points to the dialer 1 interface, where you will have to add the dialer in-band statement.
The router is in Italy and we use Basic-Net3.
I already tried dialer callback to PERMIT and dialer rotary-group insted of dialer pool with no solution
I don't remember if I used both together, I' ll verify it again at the end of the week.
Thanks for the info
Marco Parmigiani
273
