Yes it is possible.
first you will have to check which lines on the router to bind .
to understand the line numbering, you can chack the following URL.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/net_mod2/coanalog.htm#xtocid99233
Second, you can configure the 'interface group-async x' where you will be with the following command able to bind several lines :
group-range x y
you can check commands and samples on this following URL link :
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/software/config.htm#xtocid417125
You can defined on this interface the following command to save Ip address' :
IP unnumbered e0
