Cisco 3640 and VWIC 1MFT-E1 PRI
Hi ,
i have a Cisco 3640 with the following interface VWIC 1MFT-E1 . and 12 DM I want configure this router as a Accessserver . My problem is , that i can't configure at the controller e1 the pri-group 1-31 . Is it possible that the VWIC 1MFT-E1 doesn't support PRI ?
ANy hints ?
Re: Cisco 3640 and VWIC 1MFT-E1 PRI
It supports ISDN PRI signaling BUT ISDN data connection is not supported. The card can not terminate ISDN 64K or 56K data connection: It only supports voice-call termination when using ISDN PRI signaling. Pl. visit following url for more on that card
http://www.cisco.com/warp/public/788/products/vwicmf_e1.html
Hi ,
thank you for the information. In this case , i have to change the modul to a NM-1CE1B .I think this is the solution for the problem . somtetimes it is better , to read the product info .
regards
Hermann
263
