Community Member
cisco 3640 NAT ,not work correctly.if it match bug CSCDV25204 and how solve
Router: cisco 3640
Module:NM-16ESW-PWR-1GIG
ver:c3640-is-mz.122-2.XT3.bin
Now we need to do NAT,but every some interval,the router nat will disable and some time later work OK again.
I find a bug CSCDV25204 descrip as:
Release Notes
After several hours of operation, a router that has Network Address
Translation (NAT) and Port Address Translation (PAT) enabled may fail to
establish new PAT sessions. New PAT sessions cannot be established from a single add-pool with overload. This condition does not occur when a non-overload configuration is used. There is no workaround.
I want to know if this match the bug,and if we don't upgrade the IOS to Cisco IOS 12.2(8)T IP PLUS,can we solve the case? For the end user don't want to upgrading the DRAM to 96M now.
Following is the config:
------------------ show running-config ------------------
Building configuration...
Current configuration : 3766 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname jxlt-fz2
logging buffered 4096 debugging
enable secret 5 <removed>
ip subnet-zero
ip cef
fax interface-type fax-mail
mta receive maximum-recipients 0
interface Loopback0
ip address 172.17.17.3 255.255.255.255
interface FastEthernet0/0
switchport access vlan 10
no ip address
snmp trap link-status
interface FastEthernet0/1
switchport access vlan 20
no ip address
interface FastEthernet0/2
switchport access vlan 30
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface GigabitEthernet0/0
no ip address
shutdown
no negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 61.242.153.49 255.255.255.252
interface Vlan20
ip address 172.18.18.2 255.255.255.0
interface Vlan30
ip address 61.242.153.129 255.255.255.192
ip verify unicast reverse-path
interface Vlan40
no ip address
router ospf 10
log-adjacency-changes
redistribute connected subnets
network 61.242.153.49 0.0.0.0 area 0
network 172.18.18.2 0.0.0.0 area 0
distribute-list 10 in Vlan20
ip classless
ip route 0.0.0.0 0.0.0.0 61.242.153.50 200
no ip http server
logging 211.91.248.120
access-list 10 deny 172.17.0.0 0.0.255.255
access-list 10 deny 10.0.0.0 0.255.255.255
access-list 10 deny 192.168.0.0 0.0.255.255
access-list 10 deny 188.88.88.0 0.0.0.255
access-list 10 permit any
access-list 60 permit 211.91.248.0 0.0.0.255
access-list 60 permit 211.91.249.0 0.0.0.255
access-list 60 permit 210.82.103.0 0.0.0.15
access-list 60 permit 211.100.11.0 0.0.0.255
access-list 60 permit 210.52.3.0 0.0.0.255
access-list 60 permit 202.108.17.0 0.0.0.255
access-list 60 permit 61.242.153.0 0.0.0.255
access-list 60 deny any log
access-list 61 permit 211.91.248.0 0.0.0.255
access-list 61 deny any log
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 permit ip 188.88.88.0 0.0.0.255 any
access-list 111 permit icmp any host 61.242.153.129
access-list 111 deny ip any host 61.242.153.129
access-list 111 deny ip any host 61.242.153.49
access-list 111 deny ip any 172.17.0.0 0.0.255.255
access-list 111 permit ip any any
snmp-server community <removed> RO 61
snmp-server community <removed> RW 61
snmp-server host 211.91.248.124 <removed>
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
access-class 60 in
password 7 <removed>
login
end
Thank for your help!
Re: cisco 3640 NAT ,not work correctly.if it match bug CSCDV2520
Are you sure that you posted the correct version/device?
I did not find any lines for NAT in this config?!
Community Member
This is NAT config which the error is happened,If we need change some of it ?
Current configuration : 4971 bytes
! Last configuration change at 13:59:15 PRC Wed Dec 11 2002
! NVRAM config last updated at 13:57:14 PRC Wed Dec 11 2002
version 12.2
service nagle
no service pad
service tcp-keepalives-in
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname jxlt-px-wlw
enable secret 5
enable password 7
clock timezone PRC 8
ip subnet-zero
no ip source-route
ip cef
ip domain-name jxpx.cnuninet.net
ip name-server 211.91.248.129
ip name-server 211.94.33.193
no ip bootp server
description
no ip address
description
no ip address
description
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
switchport access vlan 65
no ip address
duplex full
speed 100
no ip address
shutdown
no negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 61.242.157.115 255.255.255.248
ip nat outside
interface Vlan20
ip address 61.242.157.122 255.255.255.252
ip nat outside
interface Vlan30
ip address 61.242.157.193 255.255.255.224
interface Vlan65
ip address 192.168.9.2 255.255.255.0
ip nat inside
router ospf 10
network 61.242.157.115 0.0.0.0 area 0
network 61.242.157.122 0.0.0.0 area 0
distribute-list 10 out
ip nat translation timeout 60
ip nat pool IP_POOL 61.242.157.116 61.242.157.119 netmask 255.255.255.248
ip nat inside source list 2 pool IP_POOL overload
ip classless
ip route 0.0.0.0 0.0.0.0 61.242.157.113 120
ip route 192.168.1.0 255.255.255.0 192.168.9.1
ip route 192.168.2.0 255.255.255.0 192.168.9.1
ip route 192.168.3.0 255.255.255.0 192.168.9.1
ip route 192.168.4.0 255.255.255.0 192.168.9.1
ip route 192.168.5.0 255.255.255.0 192.168.9.1
ip route 192.168.6.0 255.255.255.0 192.168.9.1
ip route 192.168.7.0 255.255.255.0 192.168.9.1
ip route 192.168.8.0 255.255.255.0 192.168.9.1
no ip http server
access-list 2 permit 192.168.0.0 0.0.15.255
access-list 10 deny 192.168.0.0 0.0.15.255
access-list 60 permit 61.242.157.0 0.0.0.255
access-list 111 permit icmp any any
access-list 111 permit ip host 192.168.9.1 any
access-list 111 deny ip 192.168.0.0 0.0.15.255 any
snmp-server community RO 61
snmp-server community RW 61
call rsvp-sync
banner motd ^CC
# Warning: If you NOT authorized to access this system, disconnect NOW. #
^C
line con 0
exec-timeout 300 0
line aux 0
line vty 0 4
access-class 60 in
exec-timeout 0 0
password 7
login
end
There seems nothing wrong with your config and your problem description matches the bug that you found. I checked also that your release is affected. It certainly is. In the bugtool this bug is said to be fixed but as far as I can see you need an XT-release to support your @#$% new module.
A release that matches these criteria is not mentioned and at present there are no updates beyond 12.2(2)XT3.
Therefore I recommend that you open a case with the TAC.
May the force be with you!
Gold
On some 12.x releases you can try no ip cef. I had a similar problem and that worked around it.
374
