07-11-2002 06:48 PM - edited 03-01-2019 11:50 PM
Hi, the network is like that 16 branches, 8 of them using 3Com 56K Lan modem and the rest using PC modem, dialing into the 3640 w/NM-16AM (slot 1) and 10BT Ethernet (slot 0) at headquarter.
There is traffic between 2 branches, say A & B (Lan Modem branches). It is the Visual FoxPro application accessing data files on both branches' Samba Servers and the headquarter ' Samba Server.This Cisco solution is to replace the existing Linux Router w/ 2 USR Couriers (and others equipments are the same) for traffic between A & B. No problems before replacement.
The problem now is that branch A cannot open/use the data file locate on branch B for file size > 9KB or vice versa. I need to allow open/use file with size >10MB.
The application prompts a "Reading Error". It seems like time out as there is no problem accessing data file in headquarter. I tried ftp from headquarter's samba to branch B's samba. "stalled" prompted in the progress bar during ftp for several times.
The questions are :
(1) how to set the line connect at a higher speed? And, how to set the modem to auto-negotiate the line speed with the remote modem as now I set the remote modem to have speed of 38400 max otherwise no connection ? Currently, I have not set any modemcap entries but using modem autoconfigure discovery. Do I need to do so?
(2) how to optimize the performance? Will PPP compress stac be useful on concerned interfaces? Lan Modem is said to support LZS.
(3) tcp header-compression useful? Stopbits 1 ?
another question :
(4) I rack mounted the cisco 3640. Do i need to ground the Cisco 3640 chasis for the NM-16AM?
Ping result (done at a PC in headquarter)
(A) to branch A's samba server
C:\WINDOWS\Desktop>ping 10.0.40.2
Pinging 10.0.40.2 with 32 bytes of data:
Reply from 10.0.40.2: bytes=32 time=142ms TTL=62
Reply from 10.0.40.2: bytes=32 time=856ms TTL=62
Reply from 10.0.40.2: bytes=32 time=289ms TTL=62
Ping statistics for 10.0.40.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 142ms, Maximum = 856ms, Average = 357ms
(B) to branch B's samba server
C:\WINDOWS\Desktop>ping 10.0.41.2
Pinging 10.0.41.2 with 32 bytes of data:
Reply from 10.0.41.2: bytes=32 time=1190ms TTL=62
Reply from 10.0.41.2: bytes=32 time=1014ms TTL=62
Reply from 10.0.41.2: bytes=32 time=2869ms TTL=62
Reply from 10.0.41.2: bytes=32 time=1481ms TTL=62
Ping statistics for 10.0.41.2:
Minimum = 1014ms, Maximum = 2869ms, Average = 1638ms
Running Config
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname HQ
enable secret 5 $1$TKTt$.fu4jDmMA/p66S9AYmC5l.
enable password 123456
username user1 password 0 password1
username user2 password 0 password2
username user3 password 0 password3
username user4 password 0 password4
username user5 password 0 password5
username user6 password 0 password6
username user7 password 0 password7
username user8 password 0 password8
username user9 password 0 password9
username user10 password 0 password10
username user11 password 0 password11
username user12 password 0 password12
username user13 password 0 password13
username user14 password 0 password14
username user15 password 0 password15
username user16 password 0 password16
ip subnet-zero
call rsvp-sync
interface Ethernet0/0
ip address 10.0.0.10 255.255.255.0
half-duplex
!async 33 40 : connect to Lan Modem
!async 33 : branch A -- 192.168.0.2 Lan Modem WAN IP
!async 34 : branch B -- 192.168.1.2 Lan Modem WAN IP
interface Async33
ip address 192.168.0.1 255.255.255.0
encapsulation ppp
async dynamic address
async mode dedicated
ppp authentication pap
interface Async34
encapsulation ppp
interface Async35
ip address 192.168.2.1 255.255.255.0
encapsulation ppp
interface Async36
ip address 192.168.3.1 255.255.255.0
encapsulation ppp
interface Async37
ip address 192.168.4.1 255.255.255.0
encapsulation ppp
interface Async38
ip address 192.168.5.1 255.255.255.0
encapsulation ppp
interface Async39
ip address 192.168.6.1 255.255.255.0
encapsulation ppp
interface Async40
ip address 192.168.7.1 255.255.255.0
encapsulation ppp
!async 41 48 : connect to single PC modem
interface Async41
ip unnumbered Ethernet0/0
encapsulation ppp
peer default ip address 10.0.0.101
interface Async42
encapsulation ppp
peer default ip address 10.0.0.102
interface Async43
encapsulation ppp
peer default ip address 10.0.0.103
interface Async44
encapsulation ppp
peer default ip address 10.0.0.104
interface Async45
encapsulation ppp
peer default ip address 10.0.0.105
interface Async46
encapsulation ppp
peer default ip address 10.0.0.106
interface Async47
encapsulation ppp
peer default ip address 10.0.0.107
interface Async48
encapsulation ppp
peer default ip address 10.0.0.108
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.2
ip route 10.0.40.0 255.255.255.0 192.168.0.2
ip route 10.0.41.0 255.255.255.0 192.168.1.2
ip route 10.0.42.0 255.255.255.0 192.168.2.2
ip route 10.0.43.0 255.255.255.0 192.168.3.2
ip route 10.0.44.0 255.255.255.0 192.168.4.2
ip route 10.0.45.0 255.255.255.0 192.168.5.2
ip route 10.0.46.0 255.255.255.0 192.168.6.2
ip route 10.0.47.0 255.255.255.0 192.168.7.2
ip route 192.168.0.2 255.255.255.255 Async33
ip route 192.168.1.2 255.255.255.255 Async34
ip route 192.168.2.2 255.255.255.255 Async35
ip route 192.168.3.2 255.255.255.255 Async36
ip route 192.168.4.2 255.255.255.255 Async37
ip route 192.168.5.2 255.255.255.255 Async38
ip route 192.168.6.2 255.255.255.255 Async39
ip route 192.168.7.2 255.255.255.255 Async40
ip http server
ip pim bidir-enable
dial-peer cor custom
line con 0
line 33 40
exec-timeout 0 0
modem Dialin
transport input all
flowcontrol hardware
line 41 48
exec-timeout 0 0
modem Dialin
transport input all
line aux 0
line vty 0 4
password 123456
login
end
Thanks a lot.
Modem Version :
slot 1 : MCOM Analog Integrated Modem Firmware Version 1.2.8
Source : IOS
Boot Firmware : 1.1.5
MIMC Firmware : 1.3.3
Modem Firmware : 2.3.17
DSP Firmware : 0.0.2
07-16-2002 01:57 PM
The default modem config should be set to allow for any modulation type, starting with the fastest (V.34) and working down from there. Modem autoconfig is not necessary and in fact should not really be used, it may end up causing more problems than it solves.
For optimization, you can consider PPP compression but the modems will already be doing compression and so PPP may not help out much (but it will cause a corresponding CPU increase). Same goes for TCP header compression, but you can try some tests to see if it helps in the end.
Yes, the chassis should be grounded.
To judge the ping results, you need to look at the quality of the individual connections - what modulation rate they connected at, etc.
