10-11-2003 01:45 AM - edited 03-02-2019 10:56 AM
For WAN,Can I use only cisco 3600 series,for example, Cisco 3660 for Central office and 3640 for remot officies? (I should use Leased line(64Kbps) and E1 Links from TDM Telco Services,E1 for Central office and 64Kbps line for remote office.) Or, I must use a better Cisco Router from 3660?
10-11-2003 05:21 AM
For E1 at Central, 3640 is sufficient. For 64k cirucits at remote ends, even smaller routers will work fine.
Thanks.
10-11-2003 10:06 PM
Another point to consider, would be how much port density you want at the Central Office. 3640 has 4 slots, 3660 has 6 slots. With a 3660, you have better options for expansion.
10-12-2003 10:39 PM
Thanks alot.
I select NM-2CE1U module for 3660(E1).How must to be configure this E1 port: Channelized E1 or Serial Interface.
