Cisco 3750 DAI Function Problem !
Dear All :
Does Any one had implement cisco3750 DAI ?
I'd setup this function at cisco3750 .
But When A'NoteBook that Setup gateway address as his NB's IP address connect to switch , then all client in vlan are fail to connect to other vlan .
So Does anyone could give me suggestion to fix this problem ?
Thanks All ~~
B/R
Ted Wen.
  • Other Network Infrastructure Subjects
Bronze
Re: Cisco 3750 DAI Function Problem !
not sure of the issue, may be you check the following link for more information on configuring Dynamic ARP Inspection :
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a00802c3079.html
Silver
Do you have DHCP snooping enabled ? ARP inspection is dependent on dhcp snooping . You first have to enable dhcp snooping to make DAI work or use static arp acls .
thnaks
Salman Z.
Dear Sir :
Yes , I had DHCP Snooping enable on Cisco3750 .
But there are DHCP snooping function only on Cisco 2950 , and No DAI Function on Cisco2950 .
So Does DAI Function could cowork with Cisco 2950 ?
B/R
Ted Wen
497
