cisco 4006 switch and 2950 switch intervlan routing needed,its urgent
Hello friends ;
We are facing a problem since so many days, it need immediate escalation immediately .i tried to best ,but it was all in vain.I hope you friends will help me out :
here is the whole problem analyzed,
vtp server :4006(96 ports)(2 ports for vlan2)
vtp client 2950 g(24 ports)(5 ports configured under vlan2.)
trunking port :gigabit
Problem :
we can communicate system of vlan2 (2950 G) on vlan2 on 4006 switch.system on vlan 1can communicatye to system on vlan 2 by assigning the gateway as ip address of vlan 1,but vlan2 is unable to communicate to vlan1 even if the gateway is assingned the ip address of vlan 2.
Remarks : Even in 4006 itself the system in vlan2 is not able to communicate to vlan 1.and backdone is LX.(from 4006 to 2950 G).
4006 switch.system (vlan2) can communincate (vlan2) (2950 G)
4006 switch.system(vlan 1) can communincate (vlan2) (2950 G)
(vlan2) (2950 G) cannot communicate 4006 switch.system(vlan 1)
(vlan2)4006 switch.system cannot communicate 4006 switch.system(vlan 1)
EAgerly awaiting ur reply;
Sandeep.s.PAtel
Re: cisco 4006 switch and 2950 switch intervlan routing needed,i
I'm not sure if I understand your problem correctly.
You need a router for inter-VLAN routing.
See an example in http://www.cisco.com/warp/public/473/50.pdf
Milan
I am not clear on your problem.
Could you please paste the config of the uplink ports on both switches?
Also, where is the inter-vlan routing performed.. on a L3 module of 4006 or are you using a router.
Harish
113
