Cisco 4500 Bootflash Issue
Folks, does anyone know where I can purchase another xbootflash simm and possibly an updated RMON EEPROM? During a flash upgrade my 4500m bootflash was corrupted, my main flash has no IOS and the version of RMON(5.1) does not provide the tftpdnld or xmodem commands to load the boot helper image via the console port. I basically have a useless router... I will be willing to reimburse someone for lending me their xbootflash simm just to get going..
Thanks....
Me again..
Thanks that is what I am trying to do, if I can find another 4500. I did not erase the boot flash. I did not even touch the furthest simm, but it is
corrupted. All I did was remove the two regular flash simms to upgrade to 16mbs of flash so I can use 12.1 for the IE lab.
Otherwise, if I can find another 45/700 with the bootflash simm I can borrow it, pop it into my router and be back in business according to Cisco's TAC site. Had this 4500 had a newer ROMMON I could have recovered the bootflash via the console port but that too is not the case. I even tried to load the boot image on the flash simm on another router, I got the image down but when I transferred the simm back to the 4500 the first file was still not
found. I was hoping for someplace that sold the simm with a boot image and/or newer ROMMON chip.
If you know of anyplace or someone willing to mail me the simm to get started I will return the simm with a check for their help..
Thanks...
/JS
1 REPLY
Re: Cisco 4500 Bootflash Issue
You may try ebay. Good luck.
346
