Cisco 6500 and Cisco 5500
I am almost positive you can not do this, BUT can a sup III engine from a 5500 go into a 6509? And if not ( more than likley )
Does the Sup I engine for the 6509 do layer 3 routing?
Re: Cisco 6500 and Cisco 5500
No. Sups are designed for their appropriate family of switches. So a Cat5xxx sup cannot be used in CAT6xxx. For the 6500 sup to do Layer 3 routing, you need to have an MSFC. Sup1 engine does not come with MSFC. We have Sup1a which comes with an optional MSFC/MSFC2
Okay then.
Maybe you can help with this delema. I had a very nice proposal for a 4006 with a sup II engine for a new back bone. The CTO found and bought a 5500 with a sup III engine, and 6 ws-x5239-rj21 blades. and a 6509 with a sup I engine. ( do not know yet if it an (a) or not ) with 48 Gigabit ports on 4 blades and a 36 10/100 copper blade.
Will the blades interchange between a 5500 and a 6500 ( ie) the fiber gigabit blades. If so I can use the 5500 for the backbone and the 6500 somewhere else?
Same thing goes for the line cards as well. You cannot interchange them between CAT5xxx and CAT6xxx
The blades are not compatable between the 5500/6500. The 6500 has the capability of 256 Gbps with the use of SFM and is loaded with features. The Cat5500 with SupIII does have features, but it an older product. If you are looking to investing in backbone, I would suggest using the Cat6500 for investment protection and new features will only be available on Cat4k/6500.
If you are going to get a 4006, get it with a SupIII instead of SupII even if you are not planning on using Layer 3 functionality.
248
