Webcast-Catalyst9k
Cisco 6509 Temperature
i have got cisco 6509, in that how do i see the temperature status? because recently when there is a power down on the server room for more than 3 hrs, cisco 6509 temperature has exceed more than 40C, so that all the LED's in the sup2 has become AMPER indications, so when i went & saw the log, it has displaed temperature exceeded the maximum threshold & current temp. 50C. so how do i see the current temperature in the cisco 6509 & also how do i change the threshold value of the temperature?
1 REPLY
Re: Cisco 6509 Temperature
Hi Anand,
To check the temp status on cat6k switch just run the command
sh env all
to be more specific
sh env temperature
Have a look at this link for more details
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_1/cmd_ref/sh_d_i.htm#wp1175721
AFAIK you cannot change the threshold value.
HTH, if yes please rate the post.
Ankur
960
