You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Cisco 6509 - Utilization % on Supervisor module
Hi All,
Is the Utilization % indicator on the Supervisor Module II, (ours is in a 6509), enabled by default, or is there are way to disable/enable it?
Darran
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Re: Cisco 6509 - Utilization % on Supervisor module
It's enabled by default and cannot be disabled. You would see it light up only if your backplane utilization is 20% and higher
1 REPLY
109
