Cisco 675 doesn't reconnect after losing connection
I have a Cisco 675 at one of my sites that apparently loses its connection and does not reestablish it. Users at the site have gotten used to power-cycling the 675 once a day or more to "make the internet work".
I suspect that there is something not configured correctly on the 675. I would like it to wait a set period of time after losing a connection and then reconnect.
What am I missing here? Is it a timeout setting? Or something else?
cbos#show timeout
Idle timeout is disabled
Session timeout is disabled
VC Reset timeout is set to 5 seconds for all connections
1 REPLY
Re: Cisco 675 doesn't reconnect after losing connection
Need to know what happens with dsl line after 675 looses the connection..
Does 675 try to re-connect?
Does ADSL line connect fine?
Does dsl/atm LED flashing after that?
It will be more helpful if you connect a console cable to 675 and issue some show commands once 675 loses the connection . Like
sh run
show int wan0-0
show dsl int wan0-0
Try adding following command "set ppp retry 3" in the config and after that issue "write" and "reboot" (as config changed) and moniter it..
103
