CISCO 7200 VXR needs reload to work
Hi ,
I have got a cisoc 7200 vxr router with two fast ethernet interfaces enabled .All it does is simple routing .Show version is
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 15-Jan-02 18:31 by pwade
Image text-base: 0x600089C0, data-base: 0x613A6000
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMENT SOFTWARE
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(3a)E5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
office-gateway2 uptime is 41 minutes
System image file is "disk1:c7200-is-mz.122-7.bin"
cisco 7204VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memory.
Processor board ID 21303036
R527x CPU at 262Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
4 slot VXR midplane, Version 2.1
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
6 FastEthernet/IEEE 802.3 interface(s)
125K bytes of non-volatile configuration memory.
125952K bytes of ATA PCMCIA card at slot 1 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Everyday I have to reboot the router for it to work for the whole day .
Can anyone suggest any ideas to solve this issue .
thanks
Raj
1 REPLY
Re: CISCO 7200 VXR needs reload to work
There are many possible causes for a router to stop responding. You shoud have a terminal connected to the routers console port and capture the messages that appear on the console when the router stops forwarding packets.
You could also feed the output from the router command "show tech" into a CCO troubleshooting tool called Output Interpreter, https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl, which can help you determine some possible causes and remedies for your problem.
You can also post the console messages and I can have a look.
Another good ideea is to upgrade the router to the latest version of IOS on CCO.
There are a number of good troubleshooting links on CCO which can help you deal with this problem:
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Software:Cisco_IOS_Test&s=Verification_and_Troubleshooting
121
