Cisco 7206VXR and 2611XM
Hi.
I have the following routers 7206VXR(HO) and 2611XM (remote).
And they are currently connected via Serial using E1 link.
And we are planning to upgrade the link from E1 to (ATM)6-10 mpbs.
Could I install a DS3 card on both of the routers to accommodate the link upgrade?
Cisco 7206XVR --- PA-A3-T3     1-Port ATM Enhanced DS3 Port Adapter
Cisco 2611XM ---- ???
I believe that I could install a PA-A3-T3 card on the 7206. But I am not sure about 2611XM.
Advance thanks for your response.
Gil
Re: Cisco 7206VXR and 2611XM
There is no DS-3 card for the 2600 series router. The 2600 is EoL so IMA probably isn't even supported. You'll need a new remote router.
Hope it helps.
you do have an NM-1A-T3.
421
