cisco 7206VXR problem
Hi, sir
There is 7206VXR
sh logg
Syslog logging: enabled (0 messages dropped, 19 messages rate-limited, 730 flushes, 0 overruns)
Console logging: level debugging, 220072 messages logged
Monitor logging: level debugging, 95925 messages logged
Buffer logging: level debugging, 198274 messages logged
Logging Exception size (8192 bytes)
Trap logging: level debugging, 15608 message lines logged
Logging to 10.238.18.17, 13280 message lines logged
Logging to 10.238.2.132, 9549 message lines logged
Log Buffer (4096 bytes):
5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Oct 15 12:12:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.238.2.130
Oct 15 12:18:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to down
Oct 15 12:18:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Oct 15 12:18:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to up
Oct 15 12:18:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Oct 15 12:19:55: %LINK-3-UPDOWN: Interface Serial1/0, changed state to down
Oct 15 12:19:55: %LINK-3-UPDOWN: Interface Serial1/1, changed state to down
Oct 15 12:19:55: %LINK-3-UPDOWN: Interface Multilink10, changed state to down
Oct 15 12:19:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Oct 15 12:19:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to down
Oct 15 12:19:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface Multilink10, changed state to down
Oct 15 12:19:57: %LINK-3-UPDOWN: Interface Serial1/0, changed state to up
Oct 15 12:19:57: %LINK-3-UPDOWN: Interface Serial1/1, changed state to up
Oct 15 12:19:57: %LINK-3-UPDOWN: Interface Multilink10, changed state to up
Oct 15 12:19:57: %LINK-3-UPDOWN: Interface Multilink10, changed state to down
Oct 15 12:19:59: %LINK-3-UPDOWN: Interface Multilink10, changed state to up
Oct 15 12:20:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface Multilink10, changed state to up
Oct 15 12:20:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to up
Oct 15 12:20:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Oct 15 12:54:30: %LINK-3-UPDOWN: Interface Serial1/1, changed state to down
Oct 15 12:54:30: %LINK-3-UPDOWN: Interface Serial1/0, changed state to down
Oct 15 12:54:30: %LINK-3-UPDOWN: Interface Multilink10, changed state to down
Oct 15 12:54:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to down
Oct 15 12:54:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Oct 15 12:54:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Multilink10, changed state to down
Oct 15 12:54:33: %LINK-3-UPDOWN: Interface Serial1/0, changed state to up
Oct 15 12:54:33: %LINK-3-UPDOWN: Interface Serial1/1, changed state to up
Oct 15 12:54:33: %LINK-3-UPDOWN: Interface Multilink10, changed state to up
Oct 15 12:54:33: %LINK-3-UPDOWN: Interface Multilink10, changed state to down
Oct 15 12:54:35: %LINK-3-UPDOWN: Interface Multilink10, changed state to up
Oct 15 12:54:36: %LINEPROTO-5-UPDOWN: Line protocol on Interface Multilink10, changed state to up
Oct 15 12:54:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Oct 15 12:54:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to up
Oct 15 13:43:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to down
Oct 15 13:43:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Oct 15 13:43:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to up
Oct 15 13:43:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Oct 15 14:44:03: %LINK-5-CHANGED: Interface Serial1/0, changed state to administratively down
Oct 15 14:44:03: %SYS-5-CONFIG_I: Configured from console by vty0 (10.238.27.25)
Oct 15 14:44:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Oct 15 14:55:00: %ALIGN-3-CORRECT: Alignment correction made at 0x6133E40C reading 0x72672F6
Oct 15 14:55:00: %ALIGN-3-TRACE: -Traceback= 6133E40C 6133EC84 6133F3C8 604E1658 604FD7D0 604FDC50 6
015DCC0 6016565C
Oct 15 16:05:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to down
Oct 15 16:05:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to up
please kindly tell what can i do ? Thank you .
1 REPLY
Re: cisco 7206VXR problem
. %ALIGN-3-CORRECT: Alignment correction made at [hex] [chars]ing [hex]
An alignment error has been detected and corrected. Alignment errors are due to misaligned reads and writes caused by a software failure. Correcting alignment errors consumes processor resources and may result in a performance penalty. If there are recurring alignment errors, CPU utilization may be seriously affected.
Recommended Action: To take advantage of recent fixes, upgrade your system to the latest Cisco IOS software release in your release train. If this message recurs, enter the show log, show alignment and show tech-support commands, contact your Cisco technical support representative, and provide the representative with the gathered information.
Additionally, the following link helps in getting more info.
http://www.cisco.com/warp/public/63/spuraccess.html
156
